Question about Music
THE U &L SOLO PANEL PLAYS VERY LOW NO VOLUME YOU CAN HEAR IT VERY LOW WHEN VOLUME IS SET AT HIGH AND SWELL IS AT HIGH ALL WORKS JUST NO VOLUME
  • Music Master
  • 5,603 Answers
Who would have any idea of what make or model device you have? Sounds like some brand of organ. We are not mind readers on this forum.
Posted on Oct 14, 2010
Which input db to choose for mixer input in carlsbro amp powerline 2000 because there is 3 options +3db 0db -3db, i think 0db is high?
That will depend on what instrument you are planning to plug into it. Set the mains and the channel volume to a low-reasonable level and plug in a play. It the input is distorting, you need to use a lower input level. If it's too quiet, you need to use a higher input level.
Mar 24, 2016 | AMP Music
Very low volume on all drums.
I don't think there is anything wrong, it has a very low line level output intentionally. This is to minimize distortion to an amp or mixer. Mine is the same and also a different brand. It is actually made so you could play it through a stereo without damaging it.
Mar 06, 2013 | Alesis DM6 Electronic Drum Set
Hello i have just bought a new fender 212r amp and i have gigged with it for around a month now. I have noticed that the amp keeps cutting out towards the end of the second set which never ever...
Numbers on volume controls mean very little as there are too many things that affect the level. If you are really driving it hard you may be causing the amp to go into thermal limiting. This is a 100 watt amp so there is a limit. The sound level from it probably can easily exceed legal limits. You should get and use a sound meter. If the amp can create 100 Db that is all you need. If you stay in that environment over a few hours, you are a candidate for hearing aids in the future. I know several musicians that are in this condition and now are wrecked. Remember that loud does not equate to QUALITY... Your group should have a sound level meter and with that you can tell if the amp is performing as it should. One thing to be careful of is high frequency feedback, even that above what you can hear that heats up the amp with frequency output you are not using. Make sure your guitar cannot "Hear" the amp. Also be careful of boosting the high frequencies. Also be careful of large bass pulses that you can see drives the speaker cones to the limit. If the cones move too far, the voice coil leaves the active magnetic area causing excess current and amp heating. Make sure there is free airflow around the amp and especially the heat sinks.
May 07, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Ok, i love the tones on this amp, but for some reason, i start to play, not even on at a high volume, just like at a nice level, ill play it for like 5-8 mins and it will shut off, like the power is still...
This is a tiny amp good for practice at low volume levels. You are likely overdriving it and the power amp chip goes into thermal protect. If you volume level is much louder than a small boom box, you are driving it too hard. Best to get a bigger amp.
Jan 26, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
When I play my Line 6 Spider III Amp (Stack), the volume and gain output is very weak even though the settings are maxed, and the tone is very strained and sharp. It basically lost all of it's kick.
Poor contacts at jacks can cause this... it results in the contacts acting like a small capacitor passing only the high frequencies at very low level.
Power amp inout jacks are notorious with switch contacts that pass the preamp signal to the power amp if the power amp input isn't used.
There are many other possibilities and only hands on troubleshooting will determine the cause.
Jul 23, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
FENDER HOT ROD DEVILLE 410 POPPING SOUND
I have answered some of this before, however I have reveiwed the schematic and as an electrical engineer I want you to do a couple tests.
First, plug in a set of headphones into the preamp out jack. Note that due to the impedance mismatch what you hear will not be very loud. Now change the state of the clean OD. Did you hear a faint pop?
Next plug a LOW impedance device OR even an instrument cable into the power amp "input" jack. Do this with the power off then warm amp up.
Now, change the state of the clean OD. Did you hear a faint pop?
Now for the analysis. If you did hear one in the first test and NOT in the second, the pop you are hearing is the "NATURE OF THE BEAST".
I can tell you from the design that the pop you hear is from coupling within the clean and OD relays within the unit. There is no cure for this within the unit other than find another brand...
I would recommend that you use an EXTERNAL pedal for the effects you want rather than trying to use the clean OD in this amp. I suspect it was never intended to be shifted during playing as I can guarantee it will pop when you shift while having anything other than dead silence (not even a bit of hum from your guitar). There is also statistical noise in the preamp that the laws of physics will not let us get around that may be enough to create a bit of a pop.
You could also use a volume pedal between the preamp output and the power amp in to throttle the volume to zero before shifting to OD.
In general I think you will find that what you are hearing is the nature of this beast.
Mar 18, 2010 | Peavey Music
About a month ago while on a gig, I noticed that the amp was cutting out when I played solos at a high volume. I play at barely half volume now, and if I go any louder, the same thing happens, it cuts...
Not likely preamp tubes. If they cut out they would fade slowly then come back slowly...
First check for marginal input jack. These take a beating and get loose and poor contacts. The vibration can cause the contact to be lost.
Also volume controls can get marginal...
Try to catch it in the act and tweek things to find someting that is affected.
Another common problem is contacts on jacks meant for effects inserting. These pass the signal through switch contacts when nothing plugged in and those contacts are "junky" to say the least.
Mar 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
Music Logo
78 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
