Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas
Pressure switch light is on so i change it out still the same
  • 990 Answers
Remove the switch and turn the system on to see if you have water coming from the tube it hooks to. If yes you have a bad switch or wire to it, so chech your wires at the switch and at the board. Blow into the switch and see if that helps. If you get no water from the tube start working back from there. If you remove the other end of the tube and still no water it could be a rust clog that you will have to clear with an ice pick or the like. If you have water there then ckeck the tube for clogs or kinks. Replace it if nessary. be sure that your filter is clean and your baskets and impeller are not cloged. If none of this helps then you may need an ignition control. If this is the case you may want to get a repairman involved, just to be sure as the part will be about three or four times a service call and he would be libal if the board dosn't get installed right.
Posted on Oct 14, 2010
My oil light comes on after higher speeds while idling at a traffic light.
It may be your oil pressure transmitter switch at fault. There's many different oil pressure transmitter switches. Here are some generic images:
oil pressure transmitter switch Google Search
It could also be that your vehicle is due an oil/filter change.
Is your oil level ok?
It's unlikely to be your oil pump at fault.
  1. Check your oil level
  2. Is the vehicle due an oil/filter change?
The oil pressure transmitter switch simply tells the engine 'low oil pressure'. This usually happens at idling speed due to a faulty transmitter switch, low oil level or there's a need for an oil change as the old oil is no longer up to the job. Oil pressure switches are easily changed.
The important thing is that you aren't getting a warning light when driving at speed. If your oil level is okay and it isn't due an oil/filter change - it probably is the oil pressure switch at fault.
For your own peace of mind try adding an oil additive.
Nov 03, 2015 | Cars & Trucks
Low oil pressure light still coming on after oil change and switch replaced
anything less than 15 psi is low... and this is for all automotive engines
Dec 28, 2013 | 2001 Oldsmobile Silhouette
Tyre pressure warning light showing when pressures are correct
Hi, the tire pressure monitor detects any changes in the tire inflation pressure. Therefore, it must initialize and store it in its memory if the tires or wheels have been replaced, re-inflated or the tires have been rotated. You can re-initialize the system by following these steps:
1. Check and make sure that your tires are inflated to the correct pressure
2. Turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (in the glove box) until the warning light turns off and then release the switch.
3. Now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
4. Initialization is *not* completed until driving at the vehicle speed of 19 mph or over for more than one hour. the tire pressure monitoring starts when initialization is completed.
May 13, 2011 | Renault 18I Cars & Trucks
On the dash there is a light on. It is a oil pan with a wrench. What does this mean?
it is an oil warning of some kind. could be low oil,or it could just be due for an oil and filter change, or it could mean there is a blocked oil filter. or low oil pressure, or a faulty oil pressure switch
best solution is just to change the oil and filter, especially if you have not done this in a while (or at all) if the light stays on, you may need to change the pressure switch (remove wire, unscrew old switch, screw in new switch, replace wire) or find out about having the service light reset if it is on as part of a routine maintenance schedule.
Feb 23, 2011 | 2003 Saturn L-Series
1992 c 1500 the ac compessor has no elect. getting to it.is it the low pressure switch?
It could be several things,I would check the fuse with a test light, the low pressure switch, the connecting
molex plug that connects to your low pressure switch could be bad and have a break on it.if all this is
okay, there is a high pressure switch at the ac compressor check to see if it has voltage. whenever you
change out the ac compressor it is recommended that you change out the high pressure switch. hope
this helps. good luck!
Feb 19, 2011 | 1992 Chevrolet C1500
Changed right front tire now reads zero on dash light is on
Your tire pressure monitor needs to be reset whenever you change or rotate your tires...
1. check and make sure that your tires are inflated to the correct pressure
2. turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (think the switch is in the glovebox, but not sure) until the warning light turns off and then release the switch.
3. now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
4. initialization is *not* completed until driving at the vehicle speed of 19 mph or over for more than one hour. the tire pressure monitoring starts when initialization is completed.
Aug 24, 2009 | 2008 Chevrolet Tahoe
The check tire pressure light and ABS auto traction sensor light keep coming on. Tire pressure is good
The tire pressure monitor detects any changes in the tire inflation pressure. Therefore, it must initialize and store it in its memory if the tires or wheels have been replaced, re-inflated or the tires have been rotated. You should be able to re-initialize the system by following these steps:
Aug 11, 2009 | 2004 Cadillac Deville
Oil light
If the oil light is on it's one of 2 things: You have no oil pressure, or the sending unit (also known as the oil pressure switch) is defective and is reading no pressure when there actually is normal pressure. You should always assume it means no pressure, because driving it this way will ruin the engine.
Mar 19, 2009 | 2000 Chevrolet Venture
Oil light comes on at certain times
First, check the oil level on the dipstick. If it is low, add the required amount of approved motor oil. If the level is correct and the light still comes on, there may be other issues.
Dec 21, 2008 | 2001 Suzuki Vitara
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas  Logo
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
