Question about Maytag SkyBox MBV1976A Beverage Dispenser
Sodas not getting cold in my skybox soda maching
  • 6 Answers
SOURCE: cannot get soda to dispense
Check tip on Skybox home page.
Posted on Jan 17, 2008
  • 66 Answers
SOURCE: Skybox
Check the compressor to see if it is running. Is it too hot to touch. If so make sure the condensor has proper air circulation to cool it. If the compressor is cool to touch and running. There is a leak in the refrigerant sealed system.The compressor isn`t doing any work because there isn`t any refrigerant in it, therefore will not creat much heat. A humming and clicking sound is typical of an overheated or damaged compressor. If the compressor isn`t running and connot start. It could be a bad start relay on the side of the compressor or a bad compressor. If you can remove the start relay, shake it and listen for a rattle sound. If it rattles, it is bad.If not. then it is time consider the cost of a repairman verses the value of the appliance. Check the cost of repair to the sealed system or maybe even replacing the compressor.I hope I have been of some help to you.
Posted on Nov 12, 2008
  • 7 Answers
SOURCE: commercial TRUE GDM soda machine
If the cooler has power, the condesor fan (bottom) and evaporator fan (top) are spinning put your hand on the compressor. Do you feel a vibration? if so, you probably have a refrigerant leak. If not (if its clicking or nothing at all) its a compressor issue.
Posted on Aug 13, 2009
  • 7 Answers
SOURCE: keeps freezing soda cans
well te best way to fix this is to lower the thing
SOURCE: replacement compressor for maytag skybox soda
A replacement compressor was NEVER made availible for this product. Be sure the problem is not just the start relay and overload. Buy a SUPCO URCO41 from an appliance parts distributor (www.marcone.com) for about $25.00. The installation instructions are on the package.
Posted on Dec 30, 2009
Pepsi soda machine
could be low on freon, drity coil, rear fan not turnig,
Apr 10, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my sky box works but when I push for a soda all
There is a little sensor board in the door where the flapper door is,you can access it when the door is open.That is what tells the main control that the can has fallen down through the door and the door has closed.
Aug 27, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Keeps freezing soda cans
May 29, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Replacement compressor for maytag skybox soda dispenser M#MPV1976AAP
May 06, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox soda dispensor does not get cold
sounds like the comp relay is bad or the compressor itself is bad the relay is inexpensive and easy to replace. the compressor on the other hand is not available to be replaced for this unit as well as cost prohibitive.
Jan 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
How clean oven??
  1. Buy an empty spray bottle and some baking soda.
    You'll find that baking soda is cheap -- especially if you buy in bulk.
  2. Using a funnel, place 3 heaping teaspoons of baking soda into the spray bottle.
    If the baking soda clogs the funnel, unclog it with water.
  3. Wash the baking soda into the spray bottle by running water into the funnel.
    Fill the bottle with water. After the bottle fills, you'll notice undissolved baking soda that has settled at the bottom of the bottle.
  4. Shake the spray bottle so that all the baking soda dissolves in the water.
    Unless all the baking soda is fully dissolved, some of it gets left behind in the bottom of the bottle as a residue.
  5. When the oven is cold, spray the baking soda and water solution on to the black stuff. Do this one or more times a day.
    It is important to work on a cold oven for two reasons:
    • Safety. You can't burn your hands if the oven is cold.
    • Containment. You'll get baking soda all over the house if you start with a hot oven. I know. I've done it.
      Starting with a cold oven solves the problem.
  6. Use your oven as you normally would. Keep spraying wet baking soda on to the top and sides of the interior of the oven between meals.
    Wet baking soda will break up the carbon sticking to the sides of the oven. Keep spraying baking soda on to the black stuff between meals until it is all gone.
    Don't worry about getting baking soda in your food. Baking soda is one of the prime ingredients of many recipes such as corn bread. It is safe to add it to your food should you do so inadvertently.
    Using this technique, the black carbon that was stuck to the sides of your oven will flow to the floor of your oven and settle there as a black carbon powder that can be wiped away.
    Your oven will look like a mess while this is in process. Choose a good time to do this.
  7. At your convenience, when the oven is cold, wipe your oven with a damp cloth.
    Eventually, you will have to wipe down your whole oven with a damp cloth. The black carbon and baking soda will will settle together on the bottom of your oven. Both are easily removed with a damp cloth.
    In theory, you will have to apply the spray bottle many times but you should only have to wipe down your oven once. Try not to wipe down the oven prematurely as this removes the active ingredient that makes the whole thing work -- the baking soda.
    Important! Let the baking soda accumulate so that it can do its job.
  8. Repeat, repeat, repeat until all the black carbon is gone.
Nov 10, 2008 | GE Kitchen Ranges
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Cannot get soda to dispense
Sounds like the child lock is turned on. Have you checked that?
Dec 27, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
91 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
