Question about HP L1520 15" LCD Monitor
The screen is dark and i can't even see the menu to adjust contrast or brightness.
    Master:
    Sergeant:
  • 460 Answers
If you can't se the menu then you can adjust it from service center.they will open it & adjust.
Posted on Oct 14, 2010
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
Screen is very dark, cannot see pictures! And can't even see the menu to try to fix it! help!
Attempt by going in a complete dark room with no lights, and see if you can see the screen at all to atempt to access the menu, sounds like that the Brightness or Contrast was adjusted too far. If that doesn't work, reccomend trying to take to place of purchase and exchange for new one.
Miller Photography
www.millerphoto.ca
Mar 18, 2010 | Coby DP-888 8-Inch Digital Photo Frame...
Low/No contrast on main screen
There should be a setup menu for "video" where the brightness and contrast can be adjusted.
Feb 10, 2010 | TruTech LMD-5702RT Portable DVD Player
Picture is dark. I need to adjust the contrast
If its starts out bright enough then rapidly goes to dark it may not be a matter of contrast. If it is the contrast hit the menu button and go into the video menu then select user defined as the setting select the contrast and adjust it to whatever specific setting you would like.
Feb 01, 2010 | Element Electronics FLX-2210 22 in. LCD...
Display screen to dark
Hello
First thing you need to do is,inside where you can see the screen, search for the brightness and contrast options in your cameras menu. Once you know where they are go outside and try to tweak it until it works. Usually you would want a higher brightness, then just adjust the contrast until your satisfied.
Hope this helps
-Chris
May 01, 2009 | Cameras
1) I own a Quasar TV model# SP 3232A. I have a dark screen but good sound.What are the possible troubles. 2)Is a service manual available for this model
If the screen is dark, then the brightness and contrast adjustment must be poor. Use the MENU key (in the TV or the Remote, either) adjust the brightness and contrast as per your viewing convenience. Service manual for this model is not in my knowledge and you should not try to repair or troubleshoot it by yourself without proper knowledge of the circuit workings inside.
Jan 23, 2009 | Quasar SP-3233 TV
Laptop screen is very dark even though harddrive is running fine
There are several reasons this could be happening but lets try adjusting your brightness/contrast settings.
Go to; Start Menu > Control Panel > Power Options
You should see something like this.
http://i298.photobucket.com/albums/mm260/mshockey89/Tech%20Support/Poweroptions.jpg
On the left hand side of the screen select Adjust the Display Brightness. You should see somthing like this.
http://i298.photobucket.com/albums/mm260/mshockey89/Tech%20Support/EditplanSetting.jpg
Now just play with the brightness settings until you get the desired effect.
Also, make sure you don't have the brightness settings too low for your off battery settings. This could be a reason as to why your having this issue. If this doesn't fix the problem, let me know.
Jan 03, 2009 | Dell Inspiron 6000 Notebook
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
HP L1520 15" LCD Monitor Logo
69 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
