Question about Whirlpool Duet WFW9550 Washer
F35 error code - Whirlpool Duet WFW9550 Washer
    President:
  • 2,468 Answers
Its the analog water pressure switch,by using non HE detergent soap this leads to a scummy build-up in the hose leading to this switch rendering it defective,you need to replace this switch
Posted on Oct 14, 2010
  • manseone Jan 04, 2011
    if the display indicates SUD followed by F35 replace this switch, its an easy fix. the cost for the part is approx. $125. cheaper if can be found online.
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
Apr 27, 2017 | Washing Machines
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code f35 and sud on washer machine/whirlpool duet front loader
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Whirlpool Duet WFW9550 Washer Logo
159 people viewed this question
Dan Webster
Dan Webster
Sal De
