Question about Canon MF3110 All-In-One Laser Printer
Paper jam error but no paper jam. Canon MF3110
SOURCE: How to dismantle Canon MF3110 to clean inside?
The service manual can be found by googling for "Canon MF3110 service manual" - however since it's not located on the Canon page I am not sure if the download is legal.
Posted on Jul 06, 2008
  • 12 Answers
SOURCE: paper jam problem in pixma mp145. E3 error.
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
supersaiyan1
  • 5 Answers
SOURCE: Canon MX700 - Error - Paper Output Slot - Paper
Try this link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
Posted on Nov 07, 2009
  • 63 Answers
SOURCE: paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Posted on Feb 03, 2010
pineworks
  • 4041 Answers
SOURCE: Canon PIXMA MP160, E3 error.
There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Canon mf3110 multifunction will only print one sheet of paper and then says check paper size
installing latest driver & toolbox from Canon USA solves problem. DO NOT USE 3rd party source..got a virus.
Dec 12, 2012 | Canon ImageClass MF3110 All-In-One Printer
Canon mf 3110 the copy printer one paper but the second is in stuck and say is paper in the jam can you help thanks
Hi.
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens.
Apr 06, 2011 | Canon MF3110 All-In-One Laser Printer
Our shop's Canon ImageRunner 3025 shows a jammed paper error, but there is not jammed paper in the copier that I can see. So what else could be triggering this jammed paper error? Thanks, Seth
You need not to pannic.Those paper jams are always there... What you need to do is to check you paper arrangement in papers tray sometime rough arrange may led to paper jams everytime
Thanks
Omari Saburi
Mar 04, 2011 | Canon ImageRunner 3025 Black and White...
There is a message called "Paper Jam". What can i do for this?
Look in your printer manual. It will tell you how to pull the paper out. If you can't see it in the front you can probably open it in the back somehow.
May 12, 2010 | Canon MF3110 All-In-One Laser Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
Paper jam
You need to open and close the front cover to reset the printer and clear the jam error message. See here and search "paper jam".
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 27, 2009 | Office Equipment & Supplies
Canon MF3110 All-In-One Laser Printer Logo
76 people viewed this question
old marine
old marine
