Question about Danby 60-Pint Dehumidifier
Just want to know how understand the MODE signs want to make it clean the air nothing else
  • 17,970 Answers
Send us excatly details about brand and model.
Posted on Oct 14, 2010
  • ZJ Limited
    ZJ Limited Oct 14, 2010
    The Danby 60 pint portable dehumidifier (DDR6009REE)
    efficiently removes moisture and is ideal for larger areas. Castor
    wheels allow for easy mobility and a convenient way of moving this Danby
    portable dehumidifier from room to room when needed. This Danby 60 pint
    dehumidifier covers a maximum area of up to 3500 square feet and has a
    variety of useful features for ease of use.
    Check in this link the Owner's Use and Care Guide Model • DDR5009REE • DDR6009REE • DDR7009REE
    I hope this helps.
Can my 3 in 1 air cooler also be used as a dehumidifier
an air cooler is a dehumidifier by definition
It cools the air around the evaporator giving you cool air and at the same time any humidity in the air is condensed into water and drained off
to understand air conditioner principles it goes something like this
we sweat and the more we sweat is because of the humidity in the air
if the air temp is 30 degrees c with a humidity of 75% then we feel that it is a very hot muggy day simply because the humidity stops the sweat from evaporating and allowing the skin to cool
Now it you take the humidity out of the air and at the same day temperature , you will actually feel cool because the sweat can evaporate and cool the skin
now you can understand that the best setting for air conditioning is 25 degrees c because if the setting is lower then the skin gets too cool because there is no humidity to restrict the evaporation of the sweat
modern spilt systems have a mode called comfort where the fan and the compressor work to maintain a constant level of humidity when sleeping and you don't get cold especially towards the morning
Jul 29, 2015 | Dehumidifiers
When turned off, makes a humming sound which it never did before. Can I ignore or do I need to fix some?
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FAD704TDP, is making a humming sound, when it is turned off. I also see that you have tried cleaning the filter and grill already, and want to know if there you should be concerned about this. You should not be alarmed by this. Providing, your dehumidifier is doing what it is supposed to do, and is taking moisture from the air, your appliance sounds like it is working fine. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire FAD704TDP Dehumidifier
Red exclamation sign blinking
Dehumidifier? Sounds like a warning of some sort. A humidifier does a simple job, removing moisture from the air. If yours is not set up to drain, it could have a full holding tank. Empty it out and give it a rinse and it should be good. Drop a couple drops of chlorine bleach in it to keep down the mold growth.
If it isn't a full tank, it could be an air filter that needs cleaning or replacing. Often these things are programmed in and needs to be cleared. Clean and or replace any and all air filters and look for a reset button.
Good luck.
Mar 15, 2014 | Dehumidifiers
Why does a dehumidifier go into defrost mode?
It gors into defrost mode if the cooling coils frost over. This usually occurs when the ambient air temperature in the room or basement reaches 65 Degrees F or lower. It's a normal operation and nothing to worry about at this point. Also, keep in mind that the air intake filter should be cleaned at least once every two weeks. This will help to reduce the frost on the cooling coils.
I hope this answered your question and thanks for choosing FixYa.
Sep 19, 2011 | Midea MDC-45AE Dehumidifier
Dehumid. runs and fan blows but no water in tank and never shuts off, 5yr. old maytag, only runs in summer
Several things can cause this problem. The leading one, is that the humidity extraction level is set to high. Lower it to 35%. One of the others, is a dirty or clogged air intake filter. Followed by obstructed air flow. You need to maintain at least a minimum of 12" clear air space around the unit. Also, most humidifiers struggle to operate correctly, if the ambient air temperature at floor level is between 40 to 60 degrees F. This will also cause the fan to run a lot if the unit is set in continuous mode, rather than a timed mode. And finally, if any doors or windows are open, the unit will run forever. Make sure all doors and windows are closed.
Here's an in home test to see if it's working properly. Move the dehumidifier to the bathroom. Plug it in turn it ON and set the humidity/moisture extraction level to 35%. Turn the shower ON hot enough to generate steam. Do Not turn the bathroom exhaust fan ON and close any windows that may be open. As you exit the bathroom, close the door. Wait 15 to 20 minutes before returning to the bathroom. Once you do, turn the shower OFF and allow the unit to run for 5 minutes more. Then check the bucket for any signs of water. If you find some, the unit is working as it should.
If you don't see any signs of water, the unit's compressor may need to be recharged with refrigerant.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 29, 2011 | Maytag M7DH65B2A Dehumidifier
My dehumidifer collect water but the fan blows hot her so it makes the room hotter
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
May 28, 2011 | Maytag M7DH65B2A Dehumidifier
Our dehumidifier has formed a sheet of ice amongst the coils and will no longer pull moisture from the air. The hole from which the water drips is completely iced over. It is 70degrees in the room and...
Turn the unit OFF and unplug it from the wall. Allow it to thoroughly thaw and remove the humidifiers cabinet to expose the cooling coils. Clean those thoroughly and coat with a very light coating of WD40. Reassemble the humidifier and turn it ON. Set your humidity control at 50% and allow the unit to run for at least one hour. Check for water collection in the bucket and for any signs of icing, after one hour. If water is in the collection bucket and no signs of icing, lower the humidity to 45% and continue. If you not any signs of icing, watch the unit, as you need to know if it automatically goes into defrost mode. The compressor should shut off, but the fan will continue to run until defrosting is completed. If it doesn't the auto defrost sensor has failed and will need to be replaced.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
May 08, 2011 | Dehumidifiers
Dehumidifier is on but nothing happens
air filter clean.
water level switch problem.
control card problem
start at these points first........
if fan is working may be compressor.
Apr 20, 2010 | Comfort-Aire BHD-501 Dehumidifier
106.57 fan runs does not work
It is dry this time of year. There may not be any water to pull out of the air.
Chris, as you may know, a dehumidifier is nothing more than a 'de-tuned' AC unit in a small package. If you are sure you have excess moisture in the air, (ideal humidity is 50%) and you have tried running a fan to circulate the air where the unit is located, your unit may require professional service.
Thanks for your interest in FixYa.com
Dec 26, 2009 | Dehumidifiers
Dehumidifiers Logo
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
