Question about Watches
Hello... I just want to ask about eta g10.211. I bought watches, which contains this quartz movement. When I start timer, the hand, which counts seconds does not move accurate. It does not hit the little stripes, which are seconds. For example, when I stop timer, the hand which count second stops between 22th and 23th second, not accurately on 22th or 23th second. Is that ok? Thanks for your soon answer
SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Posted on Oct 20, 2007
SOURCE: Tag watch second hand skips
Yes it's the battery. Please make sure to take it to someone QUALIFIED This watch requires that all the gaskets be replaced and pressure tested at the time you have the battery replaced
Donald McPherson
www.finewatchmaking.com
Posted on Dec 01, 2007
  • 203 Answers
SOURCE: second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
Posted on Nov 22, 2008
escapement
  • 2334 Answers
SOURCE: second hand movement
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Posted on Mar 07, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
Fossil twist
If you do not wind the watch, and if it is electronic it obviously has a battery. Very possible even with a new watch the battery has run out. This is especially if the watch was sitting for about a year in their inventory before you bought it.
I am not sure if your watch has a kinetic type movement where it charges the watch, or it is purely an electro-mechanical type movement. I did read it has a quartz referenced movement for the mechanical balance wheel. This would certainly involved a battery. If changing the battery is not the fix you would have to send the watch for service.
Feb 11, 2018 | Fossil Twist Series ME1013 Watch for Men
I just bought an Emporio Armani AR2020 wrist watch and when I received it, the hands on the watch wouldn't move. Do I need a battery for the watch? Is it broken?
That specific watch has a quartz movement, and it does not have a sweeping hand that moves to count the seconds. If the hour and minute hands are not moving there is a possibiliy that the battery has died. If after the battery is replaced and the hands still do not move then it's an issue with the quartz movement.
Dec 25, 2012 | Watches
Should i pull the crown to save battery if i store my quartz watch for a few months
I don't think storing a watch with the crown out accomplishes much. That I am aware of, pulling the crown out does not break the electrical connection between the battery and the watch. At least in looking at quartz movements, I don't see any electrical apparatus that insulates the crown in any way so that it could act as a switch. I think that in quartz watches that hack, pulling the crown out mechanically disengages or interferes with the drive train, but it doesn't stop the oscillator or stepper motor from running.
With quartz movements, at least those I have seen the internals of, (most ETA and ISA designs, some Rondas, a few Seikos), pulling the crown to the setting position does one of two things:
1) On better, jeweled movements - it breaks contact between the coil and battery, thus stopping the motor. The oscilator continues to be powered, but most of the current consumption is from the motor. These pulling the crown out does save battery life. Or,
2) On cheaper non-jeweled movements - it blocks the rotation of the second hand gear, and stalls the motor. These are observable by a "twitchy" second hand when the stem is out. This method actually kills the battery faster, as a stalled electric motor draws more current.
May 08, 2011 | Watches
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
How does the swiss eta g10.211 quartz chronograph work
I am not sure if I understand your question. Are you asking how this particular quartz movement operates?
All Quartz movements are pretty much the same operational wise. They can vary greatly in materials used for construction and number of jewels.
At it's basic a quartz watch uses a piece of quartz crystal called a transistor oscillator to vibrate a tuning fork. This vibration is a is brought down by micro processors to a meaningful number then converted into mechanical energy trough the movement and hands.
In the case of a chronograph it means more internal gears and jewels.
Although this is a good movement it is the low side of middle of the road.
The G10.211 is an analog display of hours and measured time. These include hours, minutes and a small jumping second as 6 o'clock. Mechanical date and counters for 1/10 second, 60 seconds and 30 minutes with "ADD" and 'SPLIT" functions. Operated by 2 push buttons.
It has 6 jewels.
If you want to know something more specific please just ask.
Hope this helps.
Dec 31, 2009 | Bulova Watch
Can i replace automatic movement for quartz in a james bond model , and can i do this myself
You can if you have following:
1) Lathe technique skills,
2) Watchmaking skills,
3) Watch engineering knowledge,
4) All necessery watchmaking hand tools,
4) Watchmakers lathe,
6) Microdrill,
7) Omega or ETA manufactured quartz movement
8) Original Omega dial for this particular movement,
9) Watch hands for this particular dial.
At the very end your watch will have no market value at all exept sentimental value for yourself.
Rate me, please.
Aug 22, 2009 | Omega Seamaster 2253.80 Wrist Watch
What type of swiss quartz movement is in a tag heuer aquaracer waf1010 ba0822?
ETA or F0 movements are usually tags number 1 choice of movements.
ETA G10.711
Jul 13, 2009 | Tag Heuer Watches
Differentiating omega model 2561.80 and a model 2531.80
Kris,
The only way to find out what model of Omega you actually own is to open it.  This should have been done by whoever you already brought it to.  Omega only prints their model #'s on the movement inside the watch.  If you open the watch, look on the movement, you'll know what model you own.
Jan 18, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Need a new stem. Can I purchase on and get it put on myself
You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
There should be no problems for supplying ETA stem.
Dec 04, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
Watches Logo
50 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
