Question about Maytag Neptune MDG5500AW Gas Dryer
NEPTUNE FRONT LOAD GAS DRYER
NO HEAT BUT STILL TURNS WHAT DO YOU THINK SHOULD BE CHECKED FOR REPAIR?
  • Anonymous Jun 18, 2008
    I have the same problem, however the igniter glows, but no flame. Every one in a while it will click & will ignite.
  • 868 Answers
1st.Look for glow from the igniter,are you getting power to the igniter?If you are getting power,and its not glowing replace the igniter.If your not getting power to the igniter replace the thermal fuse.
Posted on Jun 02, 2008
Roper gas dryer model rgd4440vq2 drum turns no heat have front off checked for power seems to be good i can only think the igniter is bad do you have a pic of part so i can compare it please!!!!!
YES!
If you will type in "Sears Parts" you will be given a place to enter your model number.
I tried it and it came up as"not a good number".
You try it.
That web site has complete diagrams for all machines.
Be blessed.
Feb 23, 2013 | Roper 29 Gas Dryer
I have a Maytag Neptune gas dryer.The power turns on, (meaning lights go on) the dryer sounds like it wants to turn but it wont turn & no heat.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 24, 2011 | Maytag Neptune MDG5500AW Gas Dryer
NO HEAT MDG5500AWW 56780829AX DRYER TURNS BUT NO
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a gas dryer, modle number mdg9700aww.There is no heat. drum rotates and fan works. Checked the heat sensor and ignitor and both work. The dryer heats intermittantly when the back is opened up....
heatman101
Nov 05, 2010 | Maytag Neptune MDG9700A Gas Dryer
Have a neptune front load dryer heat does not work either does the lights on the control panel. heat works for a second but panel where time and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Maytag Neptune MDE6700A Electric Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Mdg9700a flame wont stay burning. It wont get warm
We have a front loader neptune MDG9700AWW .gas dryer that won't heat up . I did all the proper cleaning to it but still not getting any heat to it
Nov 26, 2009 | Maytag Neptune MDG9700A Gas Dryer
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
168 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
