Hi, Dell not given facility to reboot. But command through you can reboot . To access the command prompt window from Vista or Windows 7:
Go to the Start menu
Type cmd in the Search field
Press Enter
On a Windows XP computer:
Click the Start menu
Choose Run
Type cmd
Press Enter
From an open command prompt window, you can type shutdown, and then the option you wish to execute. To shut down your computer type: shutdown /s To restart your computer type: shutdown /r To log off your computer type: shutdown /l 0r press down window key with and two time press "U" key.
plz. again restart ur pc then press F8 key just use safe mode then u receive a restore msg. plz close it and then tust go to start menu then all programs then accessories then just go to system setting after that u seen system restore program then please open it and then choose ur last good configeration date and then u restore ur window!!! bye & good luck!!!
If the computer is using Windows XP, do the following to restart the system: •Click the Start button •Click Turn Off Computer. •Cick Restart The computer will restart after the shutdown process finishes.
Also, here's is a link to the Dell 4600 Series user guide: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
The Laptop is not responding to the Software request sent to the BIOS or one is not getting there.
Best Solution is to make sure all of your Microsoft Updates are performed. Not just the Critical ones... but all that apply. You may see several hardware driver updates.
This will help the Software and Hardware to communicate with each other...
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Hi, I had the same problem, for a workaround this is what I did. I made a new shutdown shortcut. Now when I click on it the pc shutsdown fine. I actually put mine on the taskbar. Here's how I did it...
XP Users: 1. Right click the Desktop and select New /Shortcut. 2. A screen will appear asking you for a Command Line. Here's what you put in that box: For Shutdown: Shutdown -s -t 0 For Restart: Shutdown -r -t 0 For Log Off: Shutdown -l -t 0
After you've decided which of the above options to use, click the Next button and give the shortcut an appropriate name. Final Notes: 1. Now that you have the nifty little shutdown shortcut on your desktop, you may want to drag it to your taskbar for easier access (and less chance of accidental clickage). 2. I didn't like the nasty looking icon that XP gave my shortcut (it was too Win3.1 for my taste), so I changed it.
If this helps you plz rate this 'fixya'. If not leave a comment & I'll be happy to try to help you further. Thank you kindly.
have you checked that acpi is enabled in the bios and also look in control panel, then power options and check the shutdown options are correct and not set at restart.
