Question about LG DR787T DVD Recorder
Disc error Dear Sir/Madam, I have a LG dv8621p DVD player that was working fine but now it just reads disc error on the display and the disc is popped out
  • Anonymous Jun 15, 2008
    I have the same problem, I can play any
    DVD that I have previously burned, but I cannot play a normal DVD. I've done all of the obvious troubleshooting, ie turn off the dvd player, tried recycling the disc multiple times, run through the set up for any obvious settings as well as setting it back to default settings. Any advice would be great...otherwise it's going back and out of my life forever...
Recordings are not being finalize. As it starts to finalize it zips through it and then kicks it out as disc error.
Posted on Jun 15, 2008
After warranty time expires (2yearsd) my LG LRY-517 DVD combo recorder/player start to make randomly disc reading errors. During half year things has going worse. Now the situation is that it does not play...
Use lens cleaner disk to run many times. It cleans the lens and also runs cd on the disk which eventually will get rid of moisture on the circuits and restore your dvd recorder on the LG unit.
Mar 11, 2011 | Televison & Video
Disc rejection
Try using a DVD / CD cleaner disc in the unit - this might fix the problem - I had the same format error on a Toshiba unit using Sony and VBerbatim discs - once cleaned the unit worked fine
Mar 25, 2008 | Sharp DV-RW340U DVD Recorder/VCR
My LG DR389 Recorder is nearly 2 years old, was working fine until recently, when it began not to read DVD discs recorded by it:the error message "cannot read disc due to disc error"shows up.I noticed by...
A common reason for dvd players to give you error messages like "bad disc", "incorrect disc", "disc not readable", etc is that the optical lens needs to be cleaned. Dust will build up over time and prevent the device from reading the discs properly. Discs that are dirty and have finger smudges or if the discs have scratches will also cause these errors. There are some common mechanical problems that will also cause disc reading problems which you can find in my tips and tricks, just click on the link to read more about them.
You can clean your dvd player two ways, manually or by using a dvd cleaning disc. The following link will provide you with detailed information for doing cleaning the optical lens. I would suggest that you use the cleaning disc because it is easier and much faster. You can also clean your dvd discs themselves using the information here.
I hope that this information helps you solve the problem and you get many more years of use from your device. I wish you all the best. Please let me know if you need further assistance and I will do my very best to help you.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You.
Aug 13, 2010 | LG Televison & Video
LG RH1888H displays 'no disc' after inserting any type of disc.
The problem is usually caused by dirty lens. Follow the indications in this link. I wrote the article to answer to the same common problem:My player does not read disks.
Cleaning lens is the most common fix for the problem. If that does not work, then the internal drive must be replaced.
May 08, 2010 | LG RH1999H DVD Recorder/HDD Recorder
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
Turn on the unit, with remote, (no disc in player), press pause, then key 3 1 4 1 5 9
Instructions for changing region code appear on screen,
Set to Region or Disc you want to play, 1, 2, 3, 4, 5, 6, or 0 for all. Press pause again. Turn off machine.
Jun 26, 2008 | LG Televison & Video
Region code unlock
you can try this here LG DV8621P
let me know if works .
May 17, 2008 | Televison & Video
LG V8824w DVD/CD - Disc Error
I bought a lg lst3510A at a yard sale for 20 bux. Lady said that it was new and had never been used. Plugged it in and got disc error when trying to play a dvd. I removed the cover and gently slid the lens pickup to the far back I DO MEAN GENTLY.... IT SEEMS LIKE IT HAD LOST ITS HOME POSITION. This worked for me. IF YOU TRY THIS MAKE SURE THAT YOU UNPLUG THE DVD PLAYER FIRST. Good luck and I hope this works for you.
Mar 16, 2008 | Televison & Video
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
LG DV8621P
Have a look at my post for this player regarding 'progressive scan'
Hope that helps
LG DR787T DVD Recorder Logo
554 people viewed this question
Computer Repairing
Computer Repairing
