Question about Dell OptiPlex 170L PC Desktop
I have got four dell computers(170) having the problem of video output have almost tried everything,whenever i switch on the computers the amber light comes on but no video am still puzzled, and dont give me the idea of changing the power supplies or swapping the rams i have tried that,please i need your help. Please i need answers
  • 59 Answers
Try hooking them up to a good monitor that you know that works? If you have video then the other monitor is bad? if not? then you have a bad video card! I hope this helps!
Posted on Jun 03, 2011
Dell Power Edge 2900 - amber and Red A light on tape Drive
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. May also be a defective card inserted into your motherboard. Try isolating the problem by removing all components until you just have motherboard and power supply and see if it turns on.
Feb 13, 2014 | Dell Computers & Internet
Dell c521 motherboard diagrams problems
Per Dell's support site: If the power light is a solid amber, a device might be malfunctioning or incorrectly installed.
Turn off the computer and unplug from power:
I would remove and unplug everything except the memory and video card. Then plug the computer back in.
If it posts (dell screen and then a hard drive warning), turn off the computer and start reinstalling each component one at a time and turn on between each install. Hopefully one compenent will fail and you will know what is bad and needs replacing.
If the computer still had the amber light, remove one of the memory modules (hoping you have 2) and try again. If it still fail exchange the modules. If this works you have a bad memory chip, reinstall the rest the componets to double check and power on. Replace the bad chip.
If the computer still fails on both modules, remove both, you should now get a memory beep code, if not then the video card is most likely bad and will need to be replace.
Hope this helps
Jan 31, 2012 | Dell Dimension C521 PC Desktop
I'm getting a repeat beeping sound whenever I start up the computer. It's also giving an amber lights.
Definitely not a hard drive problem. It would boot, but not go to windows. This is one of two things. Power supply failure (most likely), or one of the RAM sticks went bad. I would try testing the RAM by taking one out, and trying to turn it on. Do this with both, or all four (depending on how many you have). If it still doesn't work, I would think that the Power Supply is the issue.
Dell has a set of codes that would tell you what the exact error would be based on the blinks of the amber light. If you find the pattern, you can look that up. In my professional experience it's normally the power supply.
Jul 09, 2011 | Dell Dimension 3000 PC Desktop
Amber light flashing on switching on the pc why?
HI,
A blinking amber light means that there is a problem with the power supply or the motherboard. I know that could be a number of things. Perhaps you could give some additional information.
1) Does the green light come on on the motherboard?
2) Do any/all of the fans work? Power supply or computer cooling.
3) Do you get any other lights? CD/DVD player?
You may have to get someone to see if your power supply outputs are all good.
I hope that gives you some starting points.
Thanks for using Fixya.
Nov 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ihave no amber power light only a flashing green
sounds to me like it isn't receiving a signal and stuck in power saving mode, i would recommend trying another computer that you know is outputting a signal and go from there. if that doesn't work then my guess is its broken.
Feb 03, 2010 | Dell Computers & Internet
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
No video
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Sep 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
My pc turn on before I press the switch button. Then after it starts. It wasn't able to log-in in windows. Instead, the monitor turn off automatically then the orange or amber light is flashing. I'm glad...
If the front Light is flashing amber, the systems power supply has gone bad. Request you to replace the power supply and the front I/o panel and power switch . The issue would be resolved.
Thanks
mandeep
Jun 15, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Monitor goes into standby when RS232<>TTL cable connected
Use original software for the device. Check to see if monitor is compatible with the motherboard
Sep 05, 2017 | Dell P1110 21" CRT Monitor
Dell OptiPlex 170L PC Desktop Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
