Question about Ace Hardware Econo-Heat (0601) Wall Mounted Panel Heater
Could you please inform me how to fix a broken econo-heat panel?
Great lakes balboa 2000 le wont change out of econo mode so doesnt heat up
Are there any error codes?
Is the control panel locked?
If no check your Hi Limit sensor, it is a thermal protection/overheat sensor which is the spas safety device. If that sensor is bad the spa will not operate/heat at all.
Jun 04, 2012 | Garden
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
What does econo sign mean on my toyota carina 1.8
Enoch,
Thank you for asking me to help you with your problem. However, this is either not within my area of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 03, 2011 | Cars & Trucks
My late 93 ford econo vans a/c -heat fan isnt wrkn i changed the fan motor,relay, resistor, and control panel inside the cab so what else is left? can any1 help me?
can you ground the circuit to make the blower work? have you checked all the fuses? did you check for power at the control head and look for burnt wire while replacing all the parts?
Aug 04, 2011 | Ford Econoline Cars & Trucks
Strange smell when I switch on the heater
Possible that the heaters have a loose joint which heats up the connection, the wiring or the joints that are melting.
It is best to observe carefully while the heater is ON to check for the smell emitting from within.
If so you must open to find the wiring or the heater burning up some part which comes in contact.
Feb 14, 2011 | Ace Hardware Econo-Heat (0601) Wall...
When toyota vista 1999 econo sensor lights up,
What does mean econo light in toyota corona premio 2000?
Mar 30, 2010 | 2001 Toyota Camry
I was wondering why the econo-heat plug does not have a 3 prong plug and oly has a 2 prong plug?
Looking at the picture, it has a plastic housing. Without going into a long, drawn out discussion, as long as it is sold for non-commercial use, it is allowed to have a two-prong polarized plug. With the polarized plug, the neutral wire (assuming the house is properly wired) is at the same electrical potential as a ground wire would be, and thus, there is no need for a separate ground.
If you open up a breaker box (literally pull off the front cover), you would find the neutral wires and ground wires are terminated on the same copper bar. ( I don't advise you remove the cover to your breaker box, as this will expose you to voltages of 240 volts. This is something only professionals or fools should do. )
Oct 29, 2009 | Econo Heat ECONO-HEAT USA 425watt High...
Can I Paint heater
Use high temp lkrylon spray lacquer.
Oct 01, 2009 | Ace Hardware Econo-Heat (0601) Wall...
Replacement Kettle assembly for Gold Medal 2121 Econo-pop 14
gold medal products co.
800-543-0862
10700 medallion dr
cincinnati,oh 45214
www.gmpopcorn.com
Oct 19, 2008 | Gold Medal 2121 Econo Popcorn Maker
Ace Hardware Econo-Heat (0601) Wall Mounted Panel Heater Logo
124 people viewed this question
Top Ace Hardware Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Ace Hardware Heating and Cooling Expert? Answer questions, earn points and help others
