Question about LG WM2016C
Hi, my LG washers number is WM 14336FDK, it was fine upto moving into a new home several months ago, since then it has been unpredicatable to wether it will spin the water out or not, some times it says UE or is it OE, then at times PF. I have washed just a few items at a time, UE is uneven load, but at times I have altered the washing, there as beeen just the right amount not over done it but as now of lately it will wash then bleep that it wont spin. Please help, got a huge family and the washing is pileing up. thanks.
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Posted on Nov 16, 2010
Just purchased a LG 8500HSA Mega Front Load Washer Special Order! What is the Pedestal Model Number?
Please check your model number. 8500HSA does not cross to anything on LG.COM.
Universal pedestals are for sale at Sears, Home Depot, Lowers, and Best Buy. The pedestal and machine will bolt together, that is, a bolt will run upward from the pedestal into threaded bolt holes in the bottom of the washer. If you can measure the distance from bolt hole to bolt hole on the bottom of the washer, you can check to see if the universal pedestal fits before you buy it.
Several months ago I took my front loaders off the pedestals. The pedestals were kind of nice for handling the clothes but about 40% of the time I spilled either detergent, bleach, or softener because the pedestal put the drawer too high for me.
Apr 18, 2015 | LG Washing Machines
LG WM-24321-IW frontload washer was UE error and is locked and will not drain or open
UE = Unbalance Error.
Open access door at bottom left on front of washer. Use small hose to drain water out. Door will most likely unlock when water level is lowered.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
It is not completing the cycle and flashin oe on the time screen its a lg wm 14336fdk
hello
The "oe" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while "oe" error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the "oe" error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
When washing it stays long on 4min or at time 6min. What do i do. It is still new less than 2 months
If its new, call the warranty service number- it should be in your user manual. Any fault will be repaired free of charge under manufacturer's warranty.
Mar 09, 2010 | LG WM-2277HW Front Load Washer
I need pedsteal brackets for my Lg washer
the side brackets/screws/manual should've been included. some of the new pedistals no longer use side brackets though. contact lg with pedistal model# located in drawer and research further.
May 07, 2009 | LG WM-2277HW Front Load Washer
LG washer vibration
My wife and I originally had the same problem, and it didn't help that the washroom was a slick tile floor. First add as much weight as possible to your pedestal. We have ours full of detergents, bleach, fabric softener, etc., and have several of each so that the pedestal is completely full. When mounted on the pedestal, the washer is quite top-heavy, and the added weight in the bottom helped immensely. Second, make sure your washer is level, both the feet resting on the pedestal and the feet of the pedestal itself, and tighten the secondary rings so the feet don't vibrate out of place. Last, I purchased some thin rubber padding (approximately the thickness of leather) from Home Depot in the carpet aisle. Cut some small squares and place one under each foot of the pedestal. This gives the feet some additional "grabbing power" on slick floors.
Feb 16, 2009 | LG WM-2277HW Front Load Washer
Lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Water leaking from the door and door will not unlock after washing
i just placed my order @ home depot for the LG TROMM front loader washer. i purchessed the 5 yr warrenty and i belive after reading some of the comments in here that this was a good move. I used a maytag neptune @ work and it was a peice of JUNK! it has the mildue smell everyone is talking about. i was told of a remidy for this smelly issue. pour a good amount of casscade dishwasher POWDER not liquid into the washer drum and then pour bleach into the wash slot on the fron loader and then put the washer on the longest setting and let the machine run the cycle. i hope this works for you. i will try it once a month om my front laoder when its delivered. GOOD LUCK!!!!
Nov 29, 2007 | LG WM-2277HW Front Load Washer
LG WM2016C Logo
118 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
