SOURCE: thermostat problem ?
If you start by looking on your gas valve, you should find the correct amperage to set the heat anticipator at. I am not sure if you have a forced hot water system or a steam system, but depending on the case, you may also have a second problem, which is easily addressed. If you have forced hot water, the upstairs baseboard/radiators may be airbound and need to be bleed. If you have steam, you may need to slow down the downstairs valves, and open the upstairs valves to get a balance. Hope this helps
SOURCE: The thermostat is not shutting off boiler when the
on electronic stats check that the temp is in sync with the room temp on touch pad push the menu button the two temps should be the same if not touch temp till reads correct
SOURCE: ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
SOURCE: thermostat is heating house to desired temp before programmed time
there is a installer setup in this thermostat. do you still have the book?
you will need to gain access to the installer setup/programming and in it you will find a setting called auto recovery turn it off. what this does is after a few days of initally running the system figured out it needed to come on earlier and is starting before the set time to come on... you can turn it off and then will have to adjust depending on insulation value/construction type of home how soon you want it to come on so that it reaches desired temperature when you want...
hope this helps you out,,,
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
