Question about Epson AcuLaser C3000 Printer
Paper jams regularly on Epson Aculaser C3000. Had to update firmware a while ago. Now that problem has returned I tried to run the latest update (NVMUpdate_10106.exe) but get error message that dll cannot be found.
I had the same problem. Update program is most likely not designed for Windows 7. I've launched it in Windows XP (SP3) compatibility mode and it did the work just fine.
Posted on Jan 07, 2011
Hi. Epson C3000 aculaser. It is ghosting on only on black at a pitch of +/-62mm and also printing horizontal black smudges across both side of the paper at a pitch of +/- 25mm. I have totally cleaned the...
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Sep 30, 2010 | Epson AcuLaser C3000 Printer
How do I fix a paper jam cef for epson aculaser cxn11nf?
Diagram of doors should be above control panel of printer.
Lift ADF/Scanner up. Open door "C" just below it. Lift orange photoconductor lever up to release photoconductor. Lift photo conductor up towards you. Inspect for jammed paper and remove if necessary. Replace photoconductor, close lever and door "C".
Open door "E" on rear of printer and look for jammed paper and remove. Close door "E".
Last place to look is in paper tray. Take stack of paper out and look for paper jam. Removed as needed.
These are the three places i have had jams and you will only find the jam in one of them. Most likely it will be in back in Door E
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
C3000
Hi Marko, the issue has been sorted fully by a fairly simple update to the firmware. There is a complete solution available from the address below. I spent ages messing around trying to find the correct fix for the firmware. I came across the solution below and found it 100% effective for the machines I have used it on.
http://www.tradebit.com/filedetail.php/4942713-epson-c3000-c4100-jam-at-fuser-rescue
It's not a free fix, but it is damn cheap, and I can vouch for the fact that it works.
Nov 24, 2008 | Office Equipment & Supplies
Paper Jam at A but nothing there
If you clear the jam and close the machine up again, does the print job eventually print OK. You may have to clear the jam several times before the machine prints it successfully. After the first successful print, does the machine then print ok, until the next time it is left idle for some time? If this is the case, I have a fix for you
Nov 07, 2008 | Epson AcuLaser C3000 Printer
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
Epson c1900 jam b
Paper is jammed inside the output path cover or fuser unit
Please go to this link so you can see on how to take the jammed paper out and look for Jam B (Cover AB)
http://support.epson.ru/products/manuals/000447/alc1900qr_e.pdf
Feb 05, 2008 | Epson AcuLaser C900 Printer
Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Jan 14, 2008 | Epson AcuLaser C900 Printer
My EPSON Aculaser C3000 is ghosting
Could be any of the following:
* Bad toner - try a different toner
* Unsuitable paper - try a different paper
* wrong software drivers - download the latest drivers for your operating system from the manufacturer's site.
Jan 04, 2008 | Epson AcuLaser C3000 Printer
Epson AcuLaser C3000 Printer Logo
188 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
