Question about Dishwashers
I have a Hotpoint Slimline 7801 and am looking for an explanation of the programmes it offers. The programmes 1, 2, and 3 are explained, but not all the symbols on the left-hand control. A manual would be helpful. Is one available on line?
  • Dishwashers Master
  • 3,247 Answers
The manual is available at this site - but cannot see any more programs but 1,2 ,3.
Hope this helps. Please rate the solution to help fixya serve you better.
Posted on Oct 14, 2010
Hotpoint slimeline 7801 dishwasher light comes on but wont start
When you say it won't start, do you mean a) the display is on and it won't respond, or b) it responds as it should, but after you hit the start button it doesn't go any further?
If it's b) make sure your water line is turned on. After you hit the start button it needs to make it's waterlevel setpoint to start the recirculation pump (thus shooting water everywhere). If it doesn't fill, then the washer doesn't know to go any further.
Jul 14, 2016 | Hotpoint Dishwashers
Getting an error messsage on my hotpoint ultima wm72 code is e30
It means motor problem, see below
It could be as simple as the motor requiring new brushes which can be bought quite cheaply on ebay or as complicated as the pcb motor controller being faulty. The brushes are however easily checked
http://www.youtube.com/watch?v=0GmtRBiXLFc
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.Read on....
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Hotpoint Error Messages and Error Codes
The following are an explanation of specific error codes that may appear if there is a problem with your Hotpoint washing machine, tumble dryer, dishwasher, fridge or freezer. In most cases it is recommended to book a service engineer to rectify this fault but there are certain things that you can do to minimise any inconvenience or even avoid an unnecessary engineer visit.
Don't forget, should our advice fail to solve your issue then you can book a Hotpoint appliance repair . Alternatively phone us on 08448 224 224 to book your washing machine repair.
If an explanation of an error code on your Hotpoint appliance is not shown please contact us for an explanation
Hotpoint Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a washing machine repair
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a washing machine repair
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a washing machine repair.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a washing machine repair.
  • F41 - Water level detect sequence incorrect. Book a washing machine repair.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a washing machine repair to re-programme your product.
Feb 26, 2011 | Hotpoint Washing Machines
My washing machine Hotpoint wf860 keeps showing Test. please help
The appliance appears to be in shop test mode, to de-activate it follow these steps.
there is 3 differnt variations so here are all 3.
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
These variations could explain why some of us have to make several attempts to clear tESt.
Apr 06, 2010 | Hotpoint Ultima WF865 Front Load Washer
I am looking for a manual for a hotpoint 7801 wear can i get one as never used one before and just had it given to me
Follow this link and the file sill download for you:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Dishwashers/HB7802.pdf
Apr 15, 2009 | Hotpoint 22 in. 7892 Built-in Dishwasher
Dish washer not filling with water when put on
There are a few things that can cause this problem, it could be a defective water inlet valve, it's usually located behind the lower kick plate on the left or right hand side of the dishwasher, When the washing cycle is started it sends voltage to the water inlet valve to open which allows water to enter the machine, or it could be a faulty float switch, when water enters the machine the float switch raises up which signals the water inlet valve to shut off, the float switch is located inside the dishwasher at the bottom, you can check the float switch by raising it up and down to see if it's stuck in the up position. Good luck.
Mar 21, 2009 | Dishwashers
Hotpoint wf865
press on off button till test comes up then press on off and start cancel button together for a few seconds
Jun 26, 2008 | Hotpoint Ultima WF865 Front Load Washer
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Dishwashers Logo
168 people viewed this question
Top Dishwashers Experts
