Question about Fisher and Paykel Dishwashers
Code u1 fisher& paykel model 920 - Fisher and Paykel Dishwashers
Hi, this tells you everything you need to know about a
fisher& paykel model DW820 and DW920 modelsi was also looking for the u1 error, and im sure my problem is being a male i use to much detergent (powder) that creates extra foam :o) oops lol but theres a list of things u1 error could be, i also found a few things out i wanted to know but googled before and found nothing. basically its better than the manual with everything you need to know. have fun.
http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/521766I_DW920_ugm_NZw.pdf
if your computer doesnt read pdf files like mine didnt :( when you download and open it, it will ask to check internet for a program to download that reads it, in the list that shows i chose adobe reader 8, works well, anyway this will help im sure from max
Posted on Nov 15, 2010
  • Polemicist Aug 23, 2011
    Thanks for the link to that manual Max. :)
  • Glenn Atkinson
    Glenn Atkinson Mar 15, 2013
    This link is only the owners manual with little taechnical information
3 Suggested Answers
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
A-OK
  • 10 Answers
SOURCE: error 'u1' on fisher paykel dishwasher
Water Inlet Valve!
Posted on Nov 23, 2008
How do you fix Error code U1
U1 is displayed on the LCD as a "no tap" symbol. (time out on fill is after 175 seconds)
Possible causes:
• Water turned off
• Insufficient water supply pressure
• Blocked water softener filter (if fitted)
• Spilt rinse aid causing over foam in tub
• Incorrect detergent being used
• Motor rotor
• The machine is siphoning
• Inlet valve has failed
• Controller
Jul 08, 2014 | Fisher and Paykel 23 in. DD603H SS...
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
Nov 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Model 920 shows U1 then leaks then goes to F1
Hi
Error code U1 means that the dishwasher might be taking longer time then required to fill the water and water is not draining properly as something might be blocking the drain pump assembly due to which the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. Also check the water supply and spray arm. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that it is fine. Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now' you'll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Fisher and Paykel Dishwashers
U1 code 920 model filter is clean no hoses bent or kinked ? can it be fixed ? hans
The U1 code means:-
Dishwasher attempted to fill to correct level but failed. = Water tap not turned on. Turn the water tap on.
Too much foam. Rinse aid setting too high or has been spilled. = Turn the rinse aid dial to a
lower setting or wipe the spill. Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic dishwasher. Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent
Wash pump faulty. Call your Fisher & Paykel Dealer or Authorised Service Centre.
Dishwasher not draining. = Drain hose bent or kinked. Straighten drain hose so water can flow through. Strainer blocked. Empty out the strainer and ensure the filter plate is clear of food
particles..
Feb 19, 2011 | Fisher and Paykel Dishwashers
U1 Error and Washer Stops Working
"U1 error code" means the unit has failed to prime with water within 3 minutes. Its taking longer than expected to fill with water. Check the fill valve,it might be due to water supply problem, or the spray arm might not be in the exact position place.Check the above to fix this error code.
Thank you !!
Jun 22, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
We are now getting a U1 error code on a Fisher and Paykel Nautilus dishwasher which was in the house we purchased 3 years ago and has functioned perfectly until now. There was no manual left when we took...
U1 means the unit has failed to prime with water within 3-4 minutes.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
Jul 27, 2008 | Fisher and Paykel Dishwashers
Dishwashers Logo
891 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
