Question about Faema FA60081
Safety valve leaking steam as soon as there is any pressure
    New Friend:
  • 92 Answers
Is defective and must be replace. According to the description of the problem.
Posted on Jan 14, 2011
What is the significance of steam pressure reducing valve?
It's a safety item, designed to stop this pressure reaching any dangerous level. High pressure steam can be very dangerous when let loose, as much as a blowtorch, so you only want enough to give you a good latte, no more.
Jul 13, 2016 | Coffee Makers & Espresso Machines
I replaced the pump and it's working, however, when I turned on the machine and the boiler came up, there's a stream of pressured steam coming out of releasing through the top of the machine. Any id
Hopefully, your pressure gauge is working, and if it is at 1.2 bar or so, then you have a failed anti-suction valve or boiler safety valve.
The ASV is the smaller fitting; it might be stuck, so you could try tapping the little button. The boiler safety valve is another matter - it will open at some point past 1.8 bar, which means the pressurestat is shot or its adjustment has been tampered with.
25401838-vippk3d42tdcmss1ngrlvpy2-1-1.jpgBoiler Safety Valve
It's most likely the ASV - they do get stuck open as well as closed...
Feb 05, 2015 | Astoria Argenta SAE-2 Espresso Machine
Tefal clipso not pressurizing
Attila, it could be the safety valve. Both the gasket and the safety valve have parts that are rubber or silicone. You'll want to check both of these. In what general area is pressure leaking?
Also a good resource (with forums):
http://www.hippressurecooking.com
Dec 06, 2013 | Tefal By Jamie Oliver Clipso P4110769...
No steam pressure
Leave the valve open until it starts slowly hissing, then shut off valve and wait for the pressure to build up.
Oct 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Wega espresso
Steam out of the top is a bad safety valve.
Steam out of wands when they're off is bad gaskets in the valves which usually means they need to be rebuilt.
Steam out of groups is a water blockage and/or pressure stat is going bad and causing the machine to over heat.
Can be any one of the following. Need more information to answer properly.
May 02, 2013 | Wega Mininova EPU Espresso Machine
I have a propane hot water tank that in discharging the hot water out the relief valve (Champion energy saver series)
possible problems not knowing age of unit the
control valve could be sticking open allowing gas to continue to flow until high limit is reached and shuts down valve another possible problem with the newer style back flow preventer being install by water companys the rapid heating and expansion of the water over pressures the water system causing releif valve to pop open and reclose most water heater manufacters are recommending instalation of an expansion tank to allow the growth in volume of water somewhere to go is valve constantly leaking or only during heating cycle if you could supply additional information does unit only leak when heating
or is steam expelled when releif valve opens
t-stat not opening gas valve sticking partially open
bad high limit bad pressure releif valve no expansion tank to allow for thermal expansion if steam is present and unit is boiling water inside replacement of water heater for safety concerns,would be reccomended if only water and pops couple of times water temp not over 140 degrees after most hot water has been used out of tank and is reheating most of capacity probably lack of expansion tank as the releif valve is the final safety device on a water heater is of great concern
the temp control gas valve or high limit are supposed to shut unit done long before the safety limit of releif valve is reached
Dec 11, 2009 | Water Heaters
Water is leaking into the drip tray.
Clean the chamber below the white plastic valve, there is also a small discharge that leads from there into the drain tray clean that hole also.
Second the thermostat that controls the steam may be damaged or the cpu board, the contact the controls the steam may be damaged, i have seen both of those happen on some units.
Oct 10, 2009 | Saeco Vienna SuperAutomatica Coffee...
Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
Mr. Steam CU-750 not working
Try replacing the safety valve or look at your pressure controls which may be clogged.
Dec 01, 2008 | Mr Steam Mr. Steam Commercial Steambath...
Coffee Makers & Espresso Machines Logo
191 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
