Question about HP Laserjet M2727nf Multifunction Printer
Faultcode 5 for HP laserjet M2727nf The scanner
Faultcode 5 for HP laserjet M2727nf The scanner won't start and asks to repress the ON/OFF button
  • 152 Answers
This sounds like a Scanner/Flatbed Problem. "The printer report a Scanner Error 5" This series of printers have a known problem with this component. The scanner is failing to initialize itself. The scanner does need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Posted on Feb 04, 2011
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
How to use scanner of the said printer HP LaserJet M2727nf
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01072069/c01072069.pdf.... check this link..this is the user manual of HP laserjet M2727nf MFP Printer
Nov 10, 2010 | HP Laserjet M2727nf Multifunction Printer
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
How can I fix error 5 from HP, M2727NF printer?
Unfortunatly I have seen many HP units with Scanner Error 5 . This is usualy caused by a problem in the formatter (mainboard) or scanner assembly. There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP ( 1 800 334 51 44) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model M2727nf will be extended 1 extra year (means you have 2 years coverage) if the printer has a scanner error 5. I Hope this can help ...
You can contact me directly on : eliteprintersolutions@hp.com
May 28, 2010 | HP Laserjet M2727nf Multifunction Printer
How re start my hp laserjet m2727nf, how delate
hold down the go button while you power on your hp laserjet.
Mar 19, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Scanner error 5 turn off then on
Eva, This is a common problem with this machine and more than likely the scanner will need to be replaced. You should try calling HP and see if they will cover it since it is a common problem.
Nov 13, 2008 | HP Laserjet M2727nf Multifunction Printer
HP Laserjet M2727nf Multifunction Printer Logo
887 people viewed this question
Seeker5211
Seeker5211
