Question about Genius Look 110 Webcam
Plz gave me k511b148 vc2 drivers - Genius Look 110 Webcam
I can't find a download that works, of a driver for a sony pcga-vc2 camera
From looking around the Internet just now, it appears your camera is old enough that the company no longer makes new drivers. It appears it was made for Windows 95, then updates were made for operating systems through Vista.
Dec 01, 2017 | Sony Computers & Internet
I got a 15w3-d4 sub and i cant get them to have any sound come out at 1 ohm and i have a 1ohm amp can you help me? the subs are a little older cuzz it has the - and + twice in one side and then twwice on...
The subwoofer is a dual voice coil sub. Each of those (+) and (-) goes to a voice coil. The sub can only be wired down to a 2 or 8 ohm load. For 2 ohm (which it seems like you want, so you can get the most out of your amp), you wire them in parrallel. Connect the (+) of VC1 and the (+) of VC2 to the (+) of your amp (I am assuming this is a monoblock amp), then connect the (-) of VC1 to the (-) of VC2 to the (-) of your amp. If your your amp is 2 channel, you can bridge them at the amp. (+) of one side to (-) of the other side. Series creates an 8 ohm load. (+) of amp to (+) of VC1 then (-) of VC1 to (+) of VC2, then (-) of VC2 to (-) of amp.
Feb 03, 2011 | Jl Audio 15W3-D4 Car Subwoofer
Speaker hook up.
you take the + from each coil and plug them to the + on amp and take the - on each coil and plug them to - on the amp
Sep 21, 2009 | Car Audio & Video
I am looking onto getting two Lightning Audio S3.15.VC2 subwoofers but I would like to know all of the speaker's parameters before I buy them.I have already looked at the manufacture's website and they...
S3 series is better suited for small sealed enclosures.
The S4 should be close to what you're looking for
T/S for the S4 (use the last number in each line):
Model - Strike S4.10.VC2 S4.12.VC2 S4.15.VC2
Nominal Impedance (Ohms) Dual 4 Dual 4 Dual 4
Voice Coil Diameter - (in.) 3 3 3
FS (Hz) 26.7 25.5 21.9
QTS 0.28 0.29 0.35
VAS (cu.ft.) 0.89 2.43 4.81
VAS (liter) 25.1 68.9 136.3
Xmax (in.) 0.64 0.64 0.64
Xmax (mm) 16 16 16
SPL (dB M/W) 85.2 85.7 87.6
Power Handling (RMS) 500 500 500
Power Handling (Max) 1500 1500 1500
Mounting Dia. (in.) 9-1/2 11-3/8 14-1/8
Mounting Dia. (mm) 241 289 359
Mounting Depth (in.) 5-1/2 6-1/16 7-1/8
Mounting Depth (mm) 139.7 154 181
Speaker Dis. (cu. ft.) 0.15 0.20 0.25
Speaker Dis. (liters) 4.3 5.7 7.1
Total Sealed Box Vol. (cu. ft.) 0.65 0.75 1.25
Total Sealed Box Vol. (liters) 18.4 21.2 35.4
Total Vented Box Vol. (cu. ft.) 1.75 3.0 3.25
Total Vented Box Vol. (liters) 49.6 84.9 92.0
Otherwise - call their customer service line @ (888) 881-8186
Thanks for using FixYa - A good rating for your FREE answer is appreciated.
Jul 04, 2009 | Rockford Fosgate Car Audio & Video
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My laptor
Is your computer working?
Oct 03, 2008 | HP Compaq Presario v3000z Notebook
Dual voice coil speakers
best way to do this to preserve your amp and speaker is to wire the speaker Voice coils in series.
VC1 = Voice coil 1
AMP + to VC1 +
VC1 - to VC2 +
VC2 - to Amp -
Set you amps bass gain down very low. Crank up the volume with a bass test audio track. Turn the switch to LPF or Low pass filter. Adjust a LPF to about 60 hz Adjust the bass gain up until your Sub begins to sound sitorted or choppy. Then tune the bass gain just below where it distorts. Then you are set.
Dec 07, 2007 | Jl Audio 12W6v2 Car Subwoofer
Aw 1251 audiobahn 400w. woofer
Yes, wire the Voice coils in series. This will give you at least 4 ohms.
Amp+ to VC1+
VC1- to VC2+
VC2- to Amp-
Nov 16, 2007 | AudioBahn AW1251 Car Subwoofer
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Genius Look 110 Webcam Logo
51 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
