Question about Belkin (F5D5231-4) Router
How do i password protect my internet connection on my belkin g plus mimo ad as it is unprotected any one could connect to it
    Novelist:
  • 125 Answers
Hi Lean,
I got your issue, Inorder to enable the security follow these steps,
1. Open Internet explorer and in the address bar type 192.168.2.1 and hit enter
2. You will be logged into the belkin router setup,it will ask for login password, leave it blank and click on submit
3. In the left side Under wireless , click on Security
4.In the security page , if the security mode is disable, click on the drop down and select 64 bit WEP or WPA -WPA2 (personal PSK)
5.If you select 64 bit wep, then in KEY 1 type a 10 digit number and that number is your password for your network
If you select WPA -WPA2 (personal PSK) then in the password box type any password it includes numbers and letters but atleast 8char
6.Then click on apply changes
Then your network is now secured, no one can access your wireless network without your password
Thanks & Regards,
Prema
Posted on Oct 14, 2010
G + MIMO Wireless Belkin Router - I cannot connect to the internet with my iPad. It will not accept the password to my network at home. How do I connect my iPad to my home network?
Did you configure the router, to select:
1. SSID, the "name" of your network;
2. encryption-level. Hint: use 'WPA' or 'WPA2'.
3. password to your network.
If so, then enter the SSID/password on the iPad, to connect to your network.
Jul 30, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
L get kit xbox 360
If the router has security encryption set - Then the encryption password must be entered in the XBOX configuration settings. Or you can wire the xbox directly to the Router with a Ethernet cable.
You can also Demilitarize a zone in the router for the XBOX to connect through. Unprotected ports with an xbox should be very safe - check with Microsoft for unprotected xbox internet connectivity.
Thank you for your visit to Fixya.com
Dec 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a belkin g plus mimo 3ASF5F router which is unsecured. I want to enable a security password. I have tried by using the WEP connection on properties security and adding a password but it immediately...
you need to set the password in your computer's network connection as well:
control panel --> network connections --> wireless .
find your SID network and delete it.
then re-scan for network connections and when it finds it will ask for the password.
enter the password and you should be good to go
Oct 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have belkin g plus mimo router which states connected with limited or no connectivity help please
u are typing in the wrong wireless password. acsess the router by using the IP: 192.168.2.1 in the internet explorer and click security in the left side of router's set up page.
Jan 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to put a password on Belkin GPlus Mimo 180170
you log on to the router usually an address like 192.222.222.2 etc should be in your manual and go into security then you will have an option to create a password. once this is done you will then need to re connect to your router and put the password in.go on to control panel then network connections.
Jan 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Secure internet connection with password belkin mimo router
configure that wireless router type the default ip in the browser e.g.
http://192.168.1.1 and enter the default userid admin and passwrod admin and than enable the wep and disable the dhcp if you dosent require to connect more system to your wireless network. enable the wireless security and enter the ssid code in it. This will secure your wireless connection to get access from outsider's ok
Dec 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO Problem
connect a network cable to it. the open a web browser like internet explorer and type: http:\\192.168.1.1
A user interface should appear, the default password will be either 0000 or 1234.
Connect to your broadband provider (make sure you have a DSL lilght on solid, not flashing) and see can you browse the internet, you may need to put your username and password in the browser.
If you can browse you are now ready to setup your wirelees side of your network.
Disconnect the cable and activate your wireless on your pc/laptop. Search for your network name (this can be checked when connected to your router, usually under, wireless SSID name. Call it something you reconise)
Try connect to it now...
Hope this helps...
Feb 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No connection to internet
What version of windows are you running? 98, 2000, XP, Vista?
Nov 15, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D5231-4) Router Logo
156 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
