Question about DKNY 5032 Wrist Watch
How do I set date, seconds etc on my DKNY watch. Instructions have been lost.
SOURCE: User / operating help needed...
Make sure your time display is on T1.
Press and hold the "Light" button for three seconds.
When you release it, the display will begin flashing and you can make the adjustments with the "ST/SP" and "Lap" buttons.
Posted on Feb 16, 2008
  • 29 Answers
SOURCE: Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Posted on Mar 12, 2008
SOURCE: Operating Instructions diesel DZ7069 Watch
see this page
http://www.fossilscandinavia.se/bruksanvisningar/Diesel%20Digitaler%202007.doc
Posted on Jul 23, 2008
escapement
  • 2334 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
How I set time on a men dkny digital watch
http://www.watchstation.com/wcsstore/CommonWatchStation/content/shell/brand_guides/DKNY/instructions/DKNY_Inst_ENG.pdf
Jun 05, 2015 | DKNY Watches
I have the dkny 8181 watch the date states 20th but it is the 19th how do i change the date?
pull the crown out to first position and turn clockwise or antyclockwise till you get to corect date
Aug 19, 2013 | DKNY Ny8181 Watch
Dkny 1350 how to change day
Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
May 25, 2010 | DKNY 1009 Wrist Watch
I have a DKNY OLED watch, but when I press the button for the time, it keeps resetting itself (both time and date) and no matter how many times I reset the time, it keeps resetting itself. How can I fix...
It sounds like your watch is not coming out of set mode. Make sure that when you are done setting the watch that the display is no longer flashing. This is usually done by holding down the mode or reset button.
If this is not the case then have the watch AC'd. As long as there is no problem with the circuit board this should fix the problem.
Sep 21, 2009 | DKNY Watches
Dkny ladies watch winder lost and watch stopped
DKNY is typically a quartz movement and doesn't have a "winder". I believe the part you are referring to is the crown. The watch may have stopped working for several reasons. The first three things I would suspect is that the battery died, the watch is in the set position, or the movement was damaged when the crown was coming off. If the watch is in the set position then pushing the stem in will cause the watch to run. The next thing to do is to replace the battery since it is only a few bucks. If it runs then you can replace the crown and your set. If it doesn't run I would suggest replacing the movement along with the crown and that you will have to price and see if it is within reason since this type of repair wont be covered under warranty.
Depending on the model of DKNY you may have to go through DKNY for the part. Remember that they are manufactured by Fossil. You could save yourself a lot of time by going to your local watch repair shop.
Thanks!
Sep 19, 2009 | DKNY Watches
Cant set time on watch
Timer Setting
1. In timer mode press and hold "reset" to enter setting mode; hour will begin flashing
2.Press "st/stop" to increase hours;
3. press "mode" to advance to next setting value
cheers
May 04, 2009 | Watches
DKNY 5032 Wrist Watch Logo
597 people viewed this question
Top DKNY Watches Experts
Ansel Alberto
Ansel Alberto
richie46
Are you a DKNY Watch Expert? Answer questions, earn points and help others
