Question about Acer TravelMate 611TXV Notebook
PlatinumPas - Preboot Authentication Services the computer don not read the smart card
4 Suggested Answers
SOURCE: PlatinumPAS ? preboot authentication services verify please insert a valid smartcard
Look this page: http://robotinstitute.com/comp1.jpg
under the keyboard have a switch
Posted on Jul 09, 2008
Sunnyrepairs
  • 808 Answers
SOURCE: PlatinumPas - Preboot Authentication Services
Repair ur windows or use reginout regcleaner to fix ur problem
Posted on Aug 11, 2010
fritzilog
  • 204 Answers
SOURCE: my acer travelmate 611txv has been down for some
Hi there!
This is a security feature in your Acer Travelmate computer.
Please contact Acer regarding this.
Posted on Apr 10, 2011
How do remove smart card Authentication errors in my hp compaq?
Try this Press F10 and change the security settings to remove the need for the smart card to login. This will eliminate the authentication errors associated with the faulty card.
See this web page on how to do it. HP Compaq dc5700 Business PC Computer Setup F10 Utility
Feb 16, 2015 | HP Compaq d530 SFF PC Desktop
SMART CARD AUTHENTICATION no smart card reader found
I'm only guessing here, but did you set it up for Smart Card Authentication? If so I guess if the card reader hardware fails then so does Authentication unless replaced. Anyway I'm keen to hear the perfect solution for your Laptop problem.
May 01, 2013 | HP Compaq nc6000 Notebook
Hi, i have a acer Travelmate 612TX. The bios battery was out of order. After i replaced the battery the computer displays the following message: "PlatinumPAS: PreBoot Authentication Services...
You could try to enter the bios setup, and disable the smartcard device. Then save the changes and exit. It will reboot, and it should be ok now.
Bruce
May 04, 2011 | Acer TravelMate 612TX PC Notebook
Serching for wireless switch on Nec Laptop Versapro NXseries
If You cannot enable 802.1x authentication on computers running Windows 2000 because support for 802.1x is not provided by default in Windows 2000. Therefore, the associated user interface (the Authentication tab) does not appear in the Network Connection Properties dialog box.
A supported feature that modifies the product's default behavior is now available from Microsoft, but it is only intended to modify the behavior that this article describes. Apply it only to systems that specifically require it. This feature may receive additional testing. Therefore, if the system is not severely affected by the lack of this feature, we recommend that you wait for the next Windows 2000 service pack that contains this feature.
The following files are available for download from the Microsoft Download Center:
Collapse this imageExpand this imagedownload.gif English Language Version (http://download.microsoft.com/download/win2000platform/patch/q313664/nt5/en-us/q313664_w2k_sp4_x86_en.exe)
After you apply this update, follow these steps to enable 802.1x authentication:
  1. Installing the hotfix installs the 802.1x service in the disabled state. To change the Wireless Configuration service startup to Automatic: Right-click My Computer, and then click Manage. Click Services and Applications, and then click Services. Set the Startup value for the service to Automatic, and then start the service.
  2. Open Network Connections by clicking Start, pointing to Settings, clicking Control Panel, and then double-clicking Network Connections.
  3. Right-click the wireless connection for which you want to enable or disable 802.1x authentication, and then click Properties.
  4. On the Authentication tab, do one of the following:
    • To enable 802.1x authentication for this connection, click to select the Enable network access control using IEEE 802.1x check box. By default, this check box is selected.
    • To disable 802.1x authentication for this connection, click to clear the Enable network access control using IEEE 802.1x check box.
  5. In the EAP type box, click the Extensible Authentication Protocol type that is to be used with this connection.
  6. If you click Smart Card or other Certificate in the EAP type box, you can configure additional properties if you click Properties and then follow these steps in Smart Card or other Certificate properties:
    • To use the certificate that is located in the certificate store on your computer for authentication, click Use a certificate on this computer.
    • To verify that the server certificate that is presented to your computer is still valid, click to select the Validate server certificate check box, specify whether to connect only if the server is located in a particular domain, and then specify the trusted root certification authority.
    • To use a different user name when the user name in the certificate is different from the user name in the domain to which you are logging on, click to select the Use a different user name for the connection check box.
  7. If you click Protected EAP (PEAP) in the EAP type box, your Windows user name and password are used for authentication.
  8. To specify whether the computer should try authentication on the network if a user is not logged on, if the computer or user information is not available, or both, follow these steps:
    • To specify that the computer try authentication on the network if a user is not logged on, click to select the Authenticate as computer when computer information is available check box. By default, this check box is selected.
    • To specify that the computer try authentication on the network if user information or computer information is not available, click to select the Authenticate as guest when user or computer information is unavailable check box.
Jan 05, 2011 | NEC Versa LX Notebook
PlatinumPas - Preboot Authentication Services Verify
Aug 11, 2010 | Acer TravelMate 611TXV Notebook
Using user name and password from smart card and login to the website
You can not as Samrt card authentication require AD to be configured to use smart cards. It is less likely that website is configured to use smart card authentication.
Mar 05, 2009 | Microsoft Computers & Internet
HOW DO I REMOVE SMART CARD FROM WINDOWS XP LOGIN
1. Click Start
2. Click Settings
3. Select Control Panel
4. Double click Administrative Tools
5. Double click Services
6. Scroll down and highlight the service you want to adjust
7. Right-click on it and choose Properties
8. Click the stop button.
9. Select Disable or Manual in the Startup Type scroll bar.
Services to Disable:
  1. Smart Card / Smart Card Helper - If you don’t have a smart card system, you don’t need this service. As smart cards have really never taken off… i doubt you need this. Kill it.
  2. TCP/IP NetBIOS Helper service - Unless you run NetBIOS on your system, you don’t need this service. Kill it.
  3. Uninterruptible Power Supply - Although I should have a UPS, I don’t. If you don’t, then disable this service.
  4. Remote Registry service - This service allows one to remotely edit the registry through a network connection. If you are editing your registry remotely, then you are too jedi-ninja to be reading this guide. The rest of us should have this off for security alone.
  5. Error Reporting Service - A program crashes and microsoft wants to know about it. Give up your extra CPU cycles to help Gates polish his OS, or you can just disable it.
  6. Wireless Zero Configuration - Unless you use wi-fi, you can safely stop this service. If you use wi-fi, this is actually a nice little service.
  7. Alerter - This is so useless SP2 turns this off for you. For the rest of you folks, you should turn it off too.
  8. Clipbook - This service allows you to cut and paste across your private network. Most programs that actually allow you to do this use their own ways for doing this.Useless.Stop it.
  9. Computer Browser - If you are on a LAN, keep it enabled. If not, stop it. It allows you to see the other computers on your network.
  10. FastUser Switching Compatibility - If you keep multiple users/logins on your current computer, you should leave this enabled. If you always log-in the same way as the same person, you should disable this.
  11. Messenger Service - Kill it, kill it. We’ve been saying to kill this forever.
  12. NetMeeting Remote Desktop Sharing Service - If you don’t use NetMeeting, you should stop this service.
  13. Network DDE/Network DDE DSDM - DDE DSDM was an excellent idea by Microsoft that flopped. Disable both of these.
  14. Remote Desktop Help Session Manager Service - I use remote desktop all the time. However, you should not have it enabled unless you use it.
  15. Telnet Service - This allows you to use telnet to log into your system from a remote location. It’s a security risk so don’t keep it enabled unless you use it.SP2 disables it by default now.
Nov 26, 2008 | Audiovox Computers & Internet
Dont know what it is
Turn off smart password entry
You can turn off smart password entry to reduce the chance that someone might guess your BlackBerry® device password or smart card
password based on the smart password filter that your device applies to password fields.
1. In the device options, click Security Options.
214
2. Click General Settings.
3. Set the Smart Password Entry field to Disabled.
4. Press the Menu key.
5. Click Save.
For your information .........
If you use two-factor authentication and your BlackBerry® device password or smart card password is numeric, you might be able to use
smart password entry in some password fields. When smart password entry is turned on, your device is designed to remember the format
of a password that you type in a password field. When you type the password again, your device applies a smart password filter to the
password field. If the password is numeric, a 123 indicator appears beside the password field and you do not have to press the Alt key to
type numbers. If the password is alphanumeric, an ABC indicator appears beside the password field.
Smart password entry prerequisites
• Verify that the correct smart card driver and smart card reader driver are installed on your BlackBerry® device.
• Verify that two-factor authentication is turned on
Jun 04, 2008 | RIM BlackBerry Pearl 8100
Under the keyboard have a switch. Set the key number 3 in "ON". that's all folks.....
Feb 27, 2008 | Acer TravelMate 613TXV Notebook
Acer TravelMate 611TXV Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
