Question about Lexmark X1270 All-In-One InkJet Printer
Won't feed i was given a lexmark x1270 and while i got everything downloaded etc., i cannot print anything. whenever i put paper in it, it only feeds one side. there is only one roller on the one side and that's the only side that feeds, but not all the way. if it did it would jam. all it does is wrinkle up my paper.
  • vickikelley Jul 01, 2008
    Thank you very much. I did what you said and as i was looking inside I saw a plastic piece that was stuck and preventing the paper from feeding all the way. I removed it and now it works.
Just like some one else... First I turned off the printer. Then I turned it upside down and shook it. I found a rubber band in there that one of my sons shot at his brother(...and missed).
Now the printer feeds quite well.
Also, do not capture the paper between the adjustable giude and the opposite edge. Otherwise the guide at the non-fed side acts more like a brake because of the friction. I learned that in the conveyor business.
Posted on Jun 07, 2008
Lexmark X1270 won't grab on right when I try to print
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 18, 2011 | Lexmark X1270 All-In-One InkJet Printer
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1270 paper feed problem
It seems you're having mechanical problem with that spring disconnected somewhere in the printer paper feed. Honestly, mechanical problems in the printer is difficult to troubleshoot/repair. I hope I can assist you more on this but I advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275).
Apr 26, 2010 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Paper missfeeding
seems since one side is working that you might have a bad motor in your printer. i would take it back to the store you bought it from, assuming your warranty is still within its validility .
Jul 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270 paper feeding to right
If this printer uses rubber rollers to feed the paper through the printer, try using alcohol on a cotton ball to clean the rollers. That might help restore the 'grip' on the paper.
Hope this helps, and please rate my advice.
Good luck!!
Jan 19, 2008 | Lexmark X1270 All-In-One InkJet Printer
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
