Question about Sharp AR-5316 Advanced Digital Imager Copier
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
    Guru:
  • 452 Answers
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Posted on Oct 15, 2010
TANKS, FOR YOU HELP, I HAVE PROBLEM WITH SHARP AR-5316 IS COD-L6 10
this error is a Polygon motor lock. the polygon motor drives the mirror in the laser unit. You will have to replace the laser unit or the motor/mirror unit.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
L6 sub 10
Hello sir; I'm not sure the error code can be reset or not but we can give it a try, the easiest way just turn power on and off if don't work follow following steps;
1, press "#", "interupt" "c" "interupt"
2, enter 14 then press start.
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Gunawan
Hi Gunawan,
The error 'L6' is usually an indication of problems with the Laser Unit in the copier.
Unfortunately the unit will have to be replaced and can only be done by trained personnel.
Contact your closest Sharp Dealer for assistance.
Regards
Gavin
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
I had the error message L-4 .can you halp to fix this problem?
L6 is a laser polygon motor fault, you need to replace the polygon motor in the laser unit, but try the reset code first sim 14
May 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
L6 is a fault with the laser.
To be more specific there is a set of mirrors mounted to a motor inside the laser assembly. The machine is detecting the motor is not running.
Most likely the laser itself will have to be repalced, it is also possible the main processor has failed and is not seeing the motor running.
There is the possibility of a loose connector, but that is the least likely.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Sharp AR-5316 Advanced Digital Imager Copier Logo
533 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
