Question about Zanussi Freezers
Proline pc213nf f/f is not keeping to the required -18. It is only -5 and food boxes are soggy. Is there anything I can do to freeze stuff again? Already thrown one lot of food out and replaced it.
2 Suggested Answers
  • 70 Answers
SOURCE: samsung model rs263tdpn fresh food stops cooling.
Air channels freezing? they might be blocked with foreign matter, clean them out. This might also be as simple as turning down the dial for how much you wish to cool the unit. Running it constantly at full blast is not a good idea.
Posted on Oct 08, 2012
I've got a proline Freezer and the red warning light is on..and is not freezing if it neededgas is it expensive.
how much is everything in your freezer worth???or how much will you be putting in your freezer worth??? it is cheaper to fix the freezer than losing all that money on food
May 30, 2015 | Freezers
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a freezer that does not keep tempreture. When I set it to -18 it will not get any warmer than -13 and if I try a super freeze it will take it the best part of all day to get to -18 and then it falls...
That you can get down to -18 suggests the compressor works and there is enough gas to get on with. Check the seals of the freezer for a heat leak- it should be able to grip a piece of paper in the door when it's shut. If the seal is bad then the paper will fall out or come with a gentle pull - order and replace the seal.
Sep 11, 2010 | Bosch Freezers
How to set temp in the freezer box
dear sir/madam
please find out temperature control switch on control panel then make it on ideal setting. for freezer 0 Fahrenheit (-18 celsius) for storing food and -10 fahrenheit (-23 celsius) is recommend when freezing food. please set on ideal setting.
hope answer the question
thank you
please vote!
Aug 13, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Food is unfrozen, but thermometer says temp is 28. We assumed at first that one of our kids didn't shut the door tight, but today the food is still soggy. Like I said, the temperature is 28, but the...
This is truely sad that you lost the food. Your temp gauge is definately not working it sounds like.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 06, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
Apr 15, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Freezers Logo
82 people viewed this question
Top Zanussi Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
ray gallant
Todd Arndt
Todd Arndt
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
