Need wiring diagram for jensen ka 4040hlx 500 watt amplafier
  • 1,512 Answers
Hi Rordawg01
Pretty straight foward. You need to connect power via a heavey duty cable direct from the battery to 12v terminal. Fit a fuse in line at the battery the same value as that on the amp(30a is good). Ground(chassis of the vehicle to the earth/ground connection. The remote terminal on the amp connects to your head unit to turn the amp on and off when you turn the stereo on and off. . You will need to supply signal via rca sockets to the amp also, these then connect to rca connectors that can be found at the back of your head unit.
Dont forget to disconnect the battery when doing 12 volt wiring on your car. If you wanted to get up to speed with installing car electronics, check out this site. It may help you get up to speed.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you still have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 02, 2008
What amp should I use?
Yes they information available on them they are still around. You will need a class-D 300 watt RMS amp to run them at perfect power if i remember right they are 150 watt RMS,, 450 watt max per sub.// just never mind the max it means nothing. They are a 4 ohm sub i believe so you would want to get a 1 ohm stable amp. two 4 ohm subs can be run at 1 ohm wired in series. they are actually made by audio vox corp.to wire them is easy ill give a link to do so easy to use. and handy. let me look for some info on your sub...? Yes there is info out there here is another link. Need additional help give a shout.
Rockford Fosgate Woofer WiringWizard JENSEN XS1010 Specs
Mar 07, 2016 | Jensen XS-1010 Car Subwoofer
Can i use my jensen 340 mono amp with a 500 watt 15'' subwoofer
You can, but I wouldn't advise it. Won't sound that great, your probably going to overheat your amp. It may go into protect mode. You need a bigger amp.
Dec 13, 2011 | Jensen JXP340 Car Audio Amplifier
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Mar 26, 2010 | Jensen LXA400 Car Audio Amplifier
I dont now how to wier my car audio amplafier to my car sterio. I need a diagram.
you run the RCA wires wich go to the two big plugs usally on the back left side of your stereo, they are usally red and white, run those from your stereo to your amp. the other wire is the remote wire wich is usally blue, run that from the stereo to your amp. thats the only wires you hook up to your stereo if your installing a sub woofer
Nov 17, 2009 | Car Audio & Video
Its stuck on protected. I recieved the amp for my birthday in 2000. It protected it self 90 days later. I needed an amp righr then so I went and bought a 600 watt jensen. I took the old one out of the...
whats the ohm rating of amp probally 4 what is the ohm rating for sub how many subs are you running how do you have them hooked up parallel or series is your wiring to amp right
Jul 06, 2009 | Car Audio & Video
I need a wirind diagram for a jenson lx 400 watt-
You should not need a wire diagram, all amplifiers are universal. 2 sets of speaker inputs, power "Large Red", ground "Large Black", and remote off/on "Small Blue". Thanks
Jun 08, 2009 | Jensen LXA400 Car Audio Amplifier
DON'T KNOW WHAT WIRING KIT TO USE FOR 400WATT 4 CHANNEL AMP
well i will let you know now that 400 watts running into two subs like that will never match. You will want to run only one sub or get a bigger amp. But for that amp a standard 6 gauge power wire will be sufficient to run it. The ground wire about 4 gauge is good.
Feb 23, 2009 | Jensen VM9510 Car DVD Player
Wiring diagram
what kind of wiring?
if its from the radio is it after market or factory?
Aug 15, 2008 | Car Audio & Video
Hooking Up A Sony XM754HX To Jensen BP210
hi .let me see if i can help u out ...need more info on the speaker..are the 8ohm or 4ohm ? and are the single are DVC?.....from what i can see u can bridged the amp..and u must connet the subs in series or just connet each sub +/- to +/-..and that will give u a stereo mode... u will still get great sound
Jun 21, 2008 | Sony XM-754HX Car Audio Amplifier
Protection light comming on.
I'd be inclined to check to make sure there isn't a short circuit somewhere in the output lines. Maybe a wire is crushed against the car's body or bare wires touching or badly fitted RCA plugs. All of these things could activate the protection circuit. If you have a multimeter it would make life easier but don't forget your speakers will show up as 4 ohms so that's not a short. BMW
May 31, 2006 | Jensen 100W x 4 Amplifier KA5 Car Audio...
246 people viewed this question
 Grubhead
Grubhead
