Question about RIM BlackBerry Storm 9530 Smartphone
Has white screen with app error 523 reset in the middle of the screen and when turned off goes only to that screen. unable to use phone.
  • sarahhayes Oct 14, 2010
    I'm unable to do anything. It stayes on white screen. I turn off phone goes back to white screen with app error.
    President:
  • 1,216 Answers
This is a third party application conflict and is generally seen with ms office2007 , some themes etc.
Diagnose what was the last software you installed and be aware of it in future.
What happened just before this cycle started? An update? A new Theme? A new App? The tiniest thing could be causal.You may try to directly remove them from memory card if possible
It may be that only a full device OS reload will cure the problem...and unless you already have a good backup, there will likely be no way for you to take a backup now (the backup process itself requires a stable BB). Here is a good article that might provide guidance:
Thanks
Posted on Oct 14, 2010
  • RIM Master
  • 12,061 Answers
App error 523 is very very likely a conflict with some third party app that it is attempting to load in the process... which is very likely the origin of your initial problem.
When you go to load the OS, you should have options to check what it is loading, look through those options and UNcheck any third party apps that might be in the list, like your StopTilt or TalkLock.
Below is your manual.
http://printer1.blogspot.com/2009/10/blackberry-storm-9530-user-guide-manual.html
Remove and reload the OS totally.
Providing you have the latest device OS for your carrier..
go to C Drive: Program file: Common Files: Research in Motion: App Loader : Loader.exe and run that file...
Go to device application selection and untick anything you dont need.
Click Next
I would not reccommended backup and restore. (If you are running a BES, everything should be on your pc anyway) But if you must, then do a backup)
When you get to the last page before you select 'finish' you should see an Advance Options. Click this and make sure both checkboxes are ticked.. This removes and replaces any bugs or glithces in the software.
You must make sure you have the LATEST version for your device, distributed by THE CARRIER THE DEVICE WAS MADE WITH. (Find this on the carriers website
If you're not sure, do a vendor ID check.
My blackbery is showing app error 523 reset i keep pressing reset but it wont work. when i restart my phone it shows uncaught exception :index 12>=12 then again white screen and app error 523
Hi Akira,
This error can be caused by a few different things, including faulty third party software. Have you downloaded any apps lately?
Make sure you have BlackBerry Desktop Manager installed on your computer, then unplug the battery from your BB and make sure that it is not connected to the computer. Start App Loader, then plug the USB cable into your phone. Once the phone lights up, wait to see if it starts up and if the PIN appears on your computer (in App Loader). At that point, plug in your battery. The software should load, and you can remove the third party app. If you don't think it's an app causing the problem, you can try using the repair option in the Desktop Manager. Let me know how it goes.
Apr 12, 2011 | Blackberry Curve 8350i
Uncaught exception 11>=11 bb
my phone went dead last night went i was in bed and when ive woke up this mornin ive put it on charge and the screen was white and said app error 523 reset so i reset it and it says uncaught exception:11 >11 and then went i press ok it just goes straight back to app error 523 .... and i need my phone :( how can i fix it without sending it off and paying for it?
Nov 30, 2010 | RIM BlackBerry Storm 9530 Smartphone
I turn on the phone to immediately find a pop up that says uncaught exception index 4>=4 then by its self it will go to w white screen that says app error 523 with a reset link beneath it. ive tried...
i turn on the phone to immediately find a pop up that says uncaught exception index 6>=6 then by its self it will go to white screen that says app error 523 with a reset link beneath it
Aug 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it...
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Sep 27, 2009 | RIM BlackBerry? Tour 9630 Smartphone
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
Jun 29, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry 8310 app error 523
how can i fix error 523 on a blackberry 8830
Jun 26, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
109 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
