Question about Dishwashers
Wont fill with water - Dishwashers
  • 12,061 Answers
Hi, well, If a DW will NOT fill, there is usually only a few reasons, One, the INLET valve is blocked, stuck, or faulty, two, or the drive to said solenoid is, Three/Four, and/or the Micro controller (On the main board) that drives the driver maybe faulty. one simply has to isolate replace and test. Also you need to obtain a service manual for your exact ,make and model, to be able to service your unit. To assist you I have included a DIY link below.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Otherwise please call a suitable repair professional and ask for a "Quote" before allowing any repair work to be undertaken.
Posted on Oct 14, 2010
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 800
the height of the drain hose the higher the hose gets above the washer the higher the water will fill up to
Aug 02, 2013 | Dryers
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Fills with water but wont stop filling and wont change to different cycle just keeps filling
check water pressure, it need to be about 20psi. also remove fill hoses and check the screens for dirt. clean it if necesary. also check water valve at fill hose connection. it has screens also. clean if needed. if all is ok then replace water valve.
Feb 07, 2011 | Washing Machines
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Wont fill cold water
l have a fisher paykel machine that wont fill properly on cold water only hot please help moder gw 712
Mar 20, 2009 | Washing Machines
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
