Question about Amana NTW4600VQ Washer
Always have unbalanced load - Amana NTW4600VQ Washer
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
My washer always gets unbalanced load with 7 minutes remaining.
This sounds like a problem with an unbalanced washer or unbalanced load. Your washer has four leveling rubber screws underneath. To keep it from rocking make sure all four points are touching the floor at all times. Washer machine being level is a great plus. Also it could be the amount of clothes put into the washer. The more clothes you put in the less chance of your load being uneven.
Jun 06, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio W10106480A keeps giving Unbalanced Load message and tub bumps the sides very hard and loudly
follow this step and fix it. God bless you
Washing machines are complex and have many functional components. It's always best to stop an unbalanced load, rearrange it, and re-start the washer.
Oct 01, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool awoe 8761
Is it always loud or just when it is a full load. If the load is unbalanced it will be loud. Most F/L washers today have some kind of unbalanced load detection, but they are not all that great. If it spins quietly when empty it is just an unbalanced load. Don't over load and don't mix rugs with clothes, pillows, etc...
May 19, 2012 | Whirlpool Washing Machines
Always unbalanced in the spin cycles
the machine may need to be releveled, if it is not level the clothes will have a tendancy to go to the low side and thereby causing the unbalanced condition
Mar 20, 2011 | Haier XQBM22-C Top Load Washer
My washer machine never finish the spin. Always says UL. This never happen before
UL - unbalanced load. Either there is a problem with the suspension or the load is too large.
Jan 12, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Error reading
An UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum
If you tried out all things and it did not work,
then I would say you have a bad motor. The motor has a tach in it that tells the control board if the load is balanced. If the tach is bad in the motor then it will always think the load is unbalanced.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | LG WD-1045FH Front Load Washer
My kenmore elite washing machine always has an unbalanced indicator, even if i run it empty.
Check the balance load sensor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Amana NTW4600VQ Washer Logo
23 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Terry Schneider
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
