Question about LG Computers & Internet
LG My PC - SMPS Because of high Voltage SMPS in Problem I am searching for the new SMPS in the Market. From where can I get the New SMPS in Pune City Atul Kudale 09321657756
4 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: smps transistors failed
It is difficult (or impossible) to tell exactly what caused the transistors to go bad. Sometimes they just fail because they were a little weak, or other parts went bad first and caused the transistors to be damaged. Parts get weaker and values change over time and with use, and failures can happen. The UPS can't stop damage to the power supply if some part inside the supply goes bad, but it is still good to have one. New 450 to 500 watt power supplies can be purchased for $30 to $50 (or more).
Posted on Nov 23, 2008
Tech_Wizz
  • 31 Answers
SOURCE: while switching on pc the
check the 4 pin power supply for display coming from the SMPS which should connect to the slot near the processer
Posted on Feb 07, 2012
Try to chech out the most suspected component such as capacitor, diods transistor and resistors that went bad. Unless U have 2 change the whole SMPS.
Posted on Sep 18, 2012
What could be causing my LG 60pa6500-ua plasma TV screen to intermittently turn blue and white (video and sound still on and visible) then turn back to normal?
The main power supply regulator section circuit fault. Va or Vs voltage fluctuating. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 22, 2017 | LG 60PA6500 60" 1080p Plasma TV - 16:9 -...
Hi my tv lg plasma (50pn4500)no picture but the led have on but no blind i check already voltage everything is ok but no vs voltage is power board problem or main board problem please help thanks
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 07, 2016 | LG Televison & Video
Power supply board not working, what section i have to cheke...?
May 03, 2016 | Televison & Video
Power supply output voltage
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 11, 2015 | LG Televison & Video
Samsung television smps secondary voltage 150v regulation is not OK please help
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 18, 2015 | Samsung Televison & Video
LG 50PS60 voltage regulator
About which voltage regulator you're discussing about? Its main power regulator board [SMPS]? If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 05, 2014 | LG 50PS60 50 in. Plasma HDTV
Lg diagram tv 29fu1rl
Check all the capacitors used at its horizontal output section circuit. If transistor leaks frequently, surely there will be some defective capacitors or any other fault. Check the output voltage comes out of the SMPS too. If this voltage is more than normal, this kind of fault can occur. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Televison & Video
Lg micro appears to be working, but will not heat
Hello. When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician. Just get a firm estimate before you commit to a repair because it is often better in this market place to replace as opposed to repair. it is cheaper and the new microwave is better all the way around. plus the new one is under warranty.
Joe
Mar 11, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
My computer smell like smoke and the power want come on? What to do?
your SMPS needs to be changed, its a small box ( switched mode power supply )
can be replaced by yourself. just open ur CPU .. find the place where it connects the Power chord, it should be going through a Small box SMPS .. remove it and take it to computer hardware shop , they would get you new one
Make sure you switch off your Power and unplug your power chords, its high voltage dangerous,,
Sep 02, 2009 | Dell OptiPlex GX520 PC Desktop
LG 42PX5D sparkles on black
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Apr 23, 2017 | LG 42PX5D 42 in. Plasma HDTV
Computers & Internet Logo
51 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
