Question about Panasonic KX-TG5653BP Phone
Panasonic cordless KX-TG2624BX LCD Display is not working since long time.....please help me.....
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
Posted on Apr 08, 2008
SOURCE: manual for panasonic kx-tg5240
Here's the manual (Adobe PDF) from Panasoni's site:
http://service.us.panasonic.com/OPERMANPDF/KXTG5240.PDF
Posted on Jul 23, 2008
SOURCE: Screen gone blank
I had the same fault with the handset losing it's display, phone worked great but could not see to access internal phone directory.
To strip down the phone you need a very clean hard plastic/granite
work surface and a small philips screwdriver and a small flatblade screwdriver.
First of all remove the battery cover and the batteries, put them in safe spot on the work surface (Tip: take the top cover off an aerosol tin to use for holding the screws and small parts you remove)
Remove the front facia by gently teasing it away from the body of the phone, there are 2 plastic lugs either side of the battery compartment, ease them towad the edge of the casing to release the front facia, it should then unclip easily with your thumbnail.
Near the edge of the phone you will see 2 small screws, remove them carefully and set them aside, please note these are longer than two other screws you will encounter later in the disassembly.
Seperate the two main parts of the case from the battery compartment end of the phone and work towards the other end, there are two release points on the outside of the casing, gently insert a small driver into the recess whilst applying a small amount of lifting pressure between the two casing halves and it should spring open. (Note that the case hinges on a clip at the top edge of the phone which helps with its re-assembly later.)
Please be aware that the speaker wires are soldered to the main board and should not be disconnecetd or cut!!!
At the battery end of the phone is a small strip of white plastic tape covering two short screws, these hold the cradle charging contacts to the circuit board, remove them with the metal contacts and keep them safe.
With a little coaxing the rest of the phone should now come out of the casing. Be very carefl not to touch any of the gold contacts on the circuit board or the buttons may not work, you may gently clean these using a dry microfibre cloth. DO NOT SCRUB THEM, simply rub gently a few times.
Unclip the display holder andnote the earpice comes loose, this can be fed through the plastic holder byturning it sideways and pressing it through. DO Not damage wiring!
You should now see the tiny ribbon cable on the display itself, either side of it are a thin white plastic lug which can be slid carefully away from the edge of the display to release the cable. Remove cable gently and re-insert it back into the connector it came from, ensuring it is fully home and is perfectly aligned at right angles to the display, then carefully slide the retaining lugs back into place which will lock the cable back into place.
You can now re-assemble the phone, carefully.
It worked for me, hopefully it should for you unless the display is damaged prior to or during disassembly.
Posted on Mar 09, 2009
SOURCE: Panasonic KX-T7235E Display time
press Program, **, 1234, 000, (change date & time), store, lift handset
Posted on Apr 16, 2009
HelleP531
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
Posted on Feb 11, 2010
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
I had dial locked my panasonic kx - tg 3531... but i forgot password help me please
hi my panasonic kx-tg3521bxb i had dial locked forget password help me please
Nov 22, 2010 | Panasonic GigaRange KX-TG2432 Cordless...
Panasonic KX-TG5631 that works but no display
This problem can have many solutions as it can have many origins. But one of them, and it seems the problem is synchronized, happening to several handsets within a short period of time, as if they ran out of their useful life all together, is caused by the breakage of the flat cable connecting the display to the main board. The thin film conducting material deposited on the plastic base wears off or breaks just close to the display driver making it impossible for the video signals to reach the LCD.
A solution I found was to file part of the white plastic display support base to give the flat cable some slack, and them to insert a rubber wedge between the support and the main board to keep some pressure on the cable, lifting it up a bit, bending the cable as to make the film cracks close and remake electrical contact.
It is not a permanent fix (replacing the display would be) but the phones can go back to normal operation for some time. How long? I don't know yet.
Dec 18, 2009 | Panasonic KX-TG5631 Cordless Phone
Please email a panasonic KX TG1100 instruction booklet in english
From this link you can buy a copy : http://www.cordless-phones.uk.com/cordless-phones/digital-cordless-phones/panasonic-kx-tg1100-phone or you can download one from: http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1100ne_kxtg1102ne_kxtg1103ne.html
................................................sodeep
Jun 22, 2009 | Panasonic KX-TG1100 Cordless Phone
Display light is on but the words don't show up.
Dear a1trkr,
Press the menu button on the handset and type in (1) (4) (5) THen press 1-6 for LCD Contrast.
Hope that works! I have a panasonic and I love the clarity and range.
Best of Luck, The Writer.
Jun 02, 2009 | Panasonic KX-TG9331T Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
CLIP not working
ther must be connect caller id instrument to cordless phone.
May 06, 2008 | Panasonic KX-TG2631 Cordless Phone
Panasonic KX-TCD650E
Possibly switched off and needs recharging? Press the button with the picture of the red phone next to it for a few seconds. The phone shoud beep and the lcd should come on. You may now need to put it on charge ( you will see the battery on the lcd 'charging') Hope this helps
Jul 13, 2007 | Panasonic KX TCD650E Cordless Phone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Panasonic KX-TG5653BP Phone Logo
127 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
