Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
We've got a Whirlpool ADP 755 and when we start the procedure it stops after a couple of minutes and no water is in the machine, the tab is open the filters are clean , but he wont continue ...a while ago it also made a funny buzz noise , I have no idea what to do or where to look !
  • 351 Answers
SOURCE: Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Posted on Mar 20, 2008
SOURCE: whirlpool adp 5540
try just pressing the start button down for a few seconds!
Posted on Aug 20, 2008
SOURCE: flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Posted on Sep 22, 2008
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
  • 220 Answers
SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
Posted on Sep 01, 2009
Hotpoint whirlpool ADP 4502/5
It's trying to fill with water and there is debris in the pump assy. Please remove the debris and restart the unit.
Mar 11, 2014 | Dishwashers
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
    F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
    Posible mailfunction reasons:
    The drain pump must be defective/blocked
    The siphon would have got closed
    The control board would have got damaged
    OWI defective
    Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
    Dishwashing machine whirlpool electronic control ADP 4520
    Check the Water Indicator (WI).
    When you think it should be enough water, unplug WI connector from control board and check if on WI connector is closed contact (WI written on the control board housing). If not, try with some more water. And so on. When too much water with no contact on WI, it is the one to be replaced by new one.
    NOTE: by every check UNPLUG the machine
    Jan 03, 2010 | Electrolux Dishwashers
    Whirlpool adp 5540
    My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
    It is a Whirlpool ADP 5540
    thanks for your help
    **** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
    May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
    Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
    55 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
