Question about Watches
ZOPPINI FIRENZE CRONOGRAF WATCH - Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
I have a 2010 murano and the steering wheel seems to be off to the left. has anyone had this problem and if so should i take it in
yes, I am a nissan cert. mechanic, simply take it to the dealer, and they should fix it under warranty considering you are under 3 years and 36,000 miles, its probably the steeringwheel alingment, and the can adjust the intermediate shaft and that will cure the issue!
Aug 30, 2011 | Murano Millefiori Firenze Bracelet Watch
Murano bracelet watch lost 2, small white beads & looks lopsided
Wonderful company I bought Murano Millefiori watch from here in USA is replacing for me per today's e-mail which came same morning as your.
This site is very interesting and will keep it for futher use!
Thank you for wanting to help me!!
Debbie
May 16, 2009 | Murano Millefiori Firenze Bracelet Watch
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Mar 19, 2009 | Colibri Mechanical Collection Pocket...
Zoppinni mother of pearl round watch
You just need a new pin which is relatively inexpensive. Any jeweler should be able to help you with this.
Jan 11, 2009 | Zoppini Mother of Pearl Round Face...
Stop watch hand
You have to reset your watch. Pull out crown to first click and try to move stop watch hand by pressing one of the pushbuttons. If this do not work, push the crown back in. Now pull out crown fully tto the second click and try to manipulate with pushbuttons again.
After resetting stop watch hand to 0 push the crown in completely.
Job done.
Nov 28, 2008 | Watches
I have lost the back cover of my watch. Had a new battery put in and the first time I wore it afterwards , I noticed the back covering was missing. Can you send my a new back or advise where I can a
Alot of times the company will help you with this problem, get ahold of them first. If you have no luck there, fined yourself a reputable watchmaker who probibly will be able to fit one on for you. You are lucky it is a round back,any other would probibly be near imposible to fit. If you still have problems let me know . I have been a watchmaker for 24 years, my father was a watchmaker for 50, and my grandfather was a watchmaker for 50., between what I have gathered in 24 years and my family, I should be able to help. Good Luck!!
Aug 04, 2008 | Zoppini Black Oval Face Stainless Steel...
Watches Logo
49 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
