Question about Bosch Dishwashers
Hi. I have a BOSCH SHV43A03GB/44 dishwasher and, as far as I can tell, the lower spray arm is not rotating during the cycle. It moves freely and there don't appear to be any leaks. Any ideas? Jill
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
  • 412 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Mar 20, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
SOURCE: I have bosch dishwasher SPS
It needs a new impeller which comes with its housing for the main pump ... :)))
Weavey
Posted on Aug 10, 2009
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
The top washer is not spinning
Look at the top spray arm and see if it moves freely. Inspect the middle part of the spray arm. Sometimes a tall dishes can prevent the arm from moving. Put the spray arm at 12 o'clock position and have a cup right side up in the dishwasher. Run a cycle. During the cycle the cup should be filled to the top with in 20sec and the spray arm should have moved from its position. If not then change out the spray arm and Delivery tube.
Thanks, Please rate your experience
Dec 11, 2010 | KitchenAid Dishwashers
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
Dish washer, Water leaks out of right front corner during first
it sounds like your machine is over filling. the gasket is not supposed to be under water. check the overflow float inside. it looks like a little hat or cone. it should move freely up and down. if it is stuck down, your machine will fill up too far and then leak. good luck
Oct 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Lower spray arm is not rotating
call sears help line thewy have mech that can help
Mar 14, 2009 | Kenmore 15899 Built-in Dishwasher
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
S
Jan 17, 2009 | Dishwashers
Lower spray arm not rotating
rotation is only by water coming out of angled jets at end of spray arm. probable that these are blocked. take spray arms out and run water thro centre hole and remove whatever is blocking the jets - usually rice or sweet corn
Aug 05, 2008 | Dishwashers
Dishwashers Logo
144 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
