Question about IMSI TurboCAD Deluxe v10 (00tcd510cc) for PC
Turbocad v10.1 "No filter matching this file" All files are .TCT and will not open. Any clues, please?!
5 Suggested Answers
  • 12 Answers
SOURCE: Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
Posted on May 08, 2009
Arjun007
  • 42 Answers
SOURCE: installation file doesn't match the file in the setup .cab file
the file may b corrupted ...........
Posted on Sep 21, 2009
Geekman
  • 32281 Answers
SOURCE: I recently purchased Turbocad Deluxe 2D/3D
If your associate does not have the TurboCAD program then he cannot open your TurboCAD drawing.
If he has AutoCAD or MicroStation CAD program then if you can save your CAD drawing in DXF file format (data exchange file) then they can import your CAD drawing into their CAD program.
Alternately. if your associate only needs to view your CAD drawing you can save your CAD drawing as a PDF file, then your associate can view the CAD drawing with Acrobat Reader.
Posted on Nov 24, 2010
alpug
  • 1961 Answers
SOURCE: I have TurboCAD Designer 2D
Hello!
If autosaved is enabled in your CAD, then most likely you can recover a n sv$ file of it saved in a temp folders. You can rename this file and change the extension from .sv$ to .dwg.
This link may help you find the folder where autosaved CAD file is stored
This link might help you also.
Good Luck!
Posted on May 03, 2011
How to get sent emails automatically to go into a file
You need to set up filters. Click on the gear symbol in the upper right corner. Then click on Settings. Then click on Filters. At the bottom click Create a new filter. Then you need to decide what would best filter the emails. If you want them sorted by the sender then fill out that line. If you want it filtered by subject then fill out that line, just choose what works best for your situation. Once you have filled out what you want your email filtered by (for example from businessemails@whateveraddress.com) then click on create filter with this search. Click the Skip the inbox archive it, also click Apply the label, select the label or file you want the email to go to. Click the box Also apply to # matching emails and then click Create filter. Now all emails matching the situation you set up will automatically be archived and filed under the label you set up.
Aug 03, 2014 | Google Gmail
I have TurboCAD Designer 2D for Mac V.5 December. Last night I opened my old project, made some changes and saved it. Now when I try to open that revised file I saved last night, I get error message:...
Hello!
Good Luck!
May 03, 2011 | IMSI TurboCAD Mac Designer 2D 5
Turbocad starts to register regenmethods from tcimage.dll
Re: 11.2 Program will not start
I found this on the TurboCAD forums,
"Doesn't appear in "Applications" but appears in "Processes" in Task
Manager (XP)."
I posted the following there also.
I am having the same problem sort of. I installed it on my computer
and the TCStart Module stops responding.
If I click the TC icon, the TCStart Module will open, but if I click
on "NEW" it just closes and stops responding.
I tried opening a file that I had brought home on a disc, clicked on
it, and it will not open.
If I try to open the file from the Start Module by navigating to the
file location, the whole thing stops repsonding.
[EDIT]
One more thing, at the bottom of the Start Module it says, "TurboCAD
starts to register RegenMethods from TCimages.dll...", and it stops
there. I don't ever remember seeing that before.
[/EDIT]
Mar 02, 2011 | IMSI TurboCAD Deluxe 14 (Win) Full Version...
NEED USER MANUAL FOR W3052/K7MNF-64 MOTHER BOARD
Here It is a PDF file inside a Win Rar File just download and extract files follow instructions if you need help
1. click this Link to download The file http://www.elhvb.com/mboards/oem/emachines/manuals/K7MNF-64_manual.zip
2. If you dont already have Win rar Download from this page just select which language and version of windows your have "64 bit' or most likely "32 bit" then download and install
3. after installed right click on the first winrar file and selcect extract files here so it will take the PDF file out
4 then open the PDF file with adobes PDF Reader Download Ling Here http://get.adobe.com/reader/ just download and install then click open the PDF file and There is the Manual
Mar 01, 2011 | eMachines Computers & Internet
I have four floor plan files made with Turbocad V6. When I try to run them to get a print I am greeted with the message "Failed to open;? Loading Header." I am running Windows XP Pro SRP3. Other files...
the issue is that you probably saved the files into a format that the computer u use now is unable to open and read ...so ..the thing to do is make sure you have the program they were saved in ...and gave the print command from that program ..the one that the files was saved from
if you do not have them into this computer ..install it ...or see the file type on the properties...and look on the net for a reader for that type ...or let me know the format that they were saved ...to look for a program that will read them ....also check to be sure they are saved correctly
Nov 09, 2009 | Computers & Internet
Turbocad-15 crashing with 15,000 KB file when quality rendering.
how much memory does the system have? how big is the page file?
http://www.aa1consulting.com
Jul 26, 2009 | IMSI TurboCAD Pro 15 Full Version for PC
Evaluation expired - not true!
Check the Preferences folder in the System folder to see if there is a TurboCad related file there that might contain an old date.  Delete it and see if TurboCad will start.  If it does it will probably create another file in the Preferences folder that has a new start date for the evaluation period.
May 20, 2009 | IMSI Turbocad Mac Pro 2D/3D V 2.0...
May 07, 2009 | Adobe Acrobat 7.0 Professional
IMSI TurboCAD Deluxe v10 (00tcd510cc) for PC Logo
611 people viewed this question
Top IMSI Computers & Internet Experts
Lesley Cameron
Lesley Cameron
Dan Shibata
Dan Shibata
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
