Question about Acer AL1916Ws (Silver, Black) 19 inch Monitor
Driver the display setting are the same after formatting the system though i check display settings I am using Windows Xp Professional
    Problem Solver:
  • 6 Answers
If you mean that you can't get the full color response and can not change the screen resolution beyond 640 X 480 and only 256 colors.
Sounds like you need to load the "Mother Board" driver for the VGA port. If you have a PCI video card, make sure your onboard video is turned off or disabled in the CMOS setup.
KDonald
Posted on Jun 02, 2008
No audio output devices installed. See my laptop details below for ref. Time of this report: 7/25/2011, 20:55:07 Machine name: MICROSOFT-PC Operating System: Windows 7 Ultimate 32-bit (6.1,...
Go to device manger and check Sound, video and game controller option if the drivers are not installed
Install the audio drivers using the HP cd also check 4 the display drivers
Jul 25, 2011 | Computers & Internet
How to format my compaq pressario cq40 604tx laptop with xp
hi
Boot from your XP install CD and select the option to format the C:
drive. If you don't have an install CD, use the "System Restore" CD or
DVD that came with your system. These restore your system to factory
settings. There're still other ways to format your C: drive, but
without either an install CD or restore one, you'll end up with an
unusable system after formatting the C: drive.
If you use the XP install CD, you'll need to be SURE you have all the
drivers for things like your DVD/CD drive, NIC, video, audio, modem, etc.
Jul 02, 2010 | Microsoft Windows XP Professional With...
In display setting it shows only 4 bit colour. and colour setting is not changing?
Have you installed you mother board and/ or VGA drivers if not do so.
Other wise update your display settings, be it Windows or your screen driver.
Good Luck
Mar 03, 2010 | Microsoft Windows XP Professional With...
IBM ThinkPad T42 Srceen view
The problem is the video driver, either it has been corrupted or uninstalled, that is why the display is set to standard VGA settings of 640X480 with 16 colors.
You can check this by going to the Control Panel - Display - Settings - Advance and check the Adapter.
To fix this problem install the Video driver.
Mar 01, 2009 | IBM ThinkPad T42 Notebook
I dont have the driver of sound
We need to know what model.
You should try using the Windows Update function first though, make sure you use the "custom" not the express. If Windows is able to detect the driver then it will show up under the hardware category. If not just make sure you post your exact ibm model and we'll find it.
If you have any more questions feel free to ask and please don't forget to rate my solution.
Thanks!
Feb 24, 2009 | Microsoft Windows XP Professional With...
Windows xp not installes on hp notebook
It means your hard drive is not connected to the computer. Go into the BIOS and check to make sure it shows up. The best thing, set the BIOS to the default setting.
Feb 21, 2009 | Microsoft Windows XP Professional With...
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Control Panel Display Icon Won't open: Windows XP Professional
it should be in the standard windows location in C:\Documents and Settings\theusername\Application Data\Microsoft\Internet Explorer
if you used firefox to set as background might be under
C:\Documents and Settings\theusername\Application Data\Mozilla\Firefox
i looked at my driver for the nview desktop manager but i seem to not have it in my driver. usualy in documents and settings\username right click search. advanced.. search hidden. then search for *.bmp
Nov 03, 2007 | Nvidia GeForce 6600 Graphic Card
Step by step for system recovary on xp pro
First find the windows product key, and write it down. the firts thing you should do is to enter the BIOS setup. When you switch on your system you may be asked to press a certian key. for e.g. "Press DEL to enter setup". press the relevant key. Change the boot sequence to set the CD ROM first.
then you put your windows CD in  the drive and reboot the system.
When it displays "press any key to boot from CD." press any key.
After a while, the system displays options for Installation. Press Enter key.
Then folow the instaruction on screen.
When it displays a message like this...
"C:\windows xp professional"
Press enter and then just follow the onscreen instructions like a normal installation. This way you would be able to recover your windows XP system and bootloader if damged.
Do not select the option to format, partition or delete your Documents and settings. this may damage your system and personal files.
Oct 29, 2007 | Microsoft Windows XP Professional for PC
Acer AL1916Ws (Silver, Black) 19 inch Monitor Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
