Question about Lite On Televison & Video
My cdrw 32x12x40 & DVD rom models Pc will not run them. even go to start and run E: or D: Pc says go to control panel and cong. can not find anything to fix the problem.
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
HERE SHIVAM
your problem is so easy
just listen and fdollow these steps-
go computer>prop>device manager>select drive or rom which you want to install>right click on it>update driver>select 1st option> then second one>
then select dont search and next it
and after completing
restart it ok
i have the same prob but now it solved
do it now
Posted on Jun 02, 2008
    Brigadier General:
  • 6,966 Answers
Your concern could either be a hardware issue or a software configuration.
A couple of queries pls:
1. What OS; XP or Vista?
2. Were THE CD Writer and/or DVD running before and stop working or upon installation, they did not run at all not even once?
3. Have you checked the cable that attaches them to the motherboard?
4. Have you verified whether they are set to master or slave as the case maybe as to how they are attached in relation to an HD or to the other?
5. Have you tried other CD writer or DVD to confirm if the old ones are still really OK?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive cannot read to boot osDell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 22, 2012 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
I still can not get the Laptop running Xp Pro sp3 to see the CDRW/dvd combo drive. I followed all of the previous instructions but when I get to the Place where I'm supposed to delete Upper Filters. There...
make sure that the cdrw-dvd rom is getting enough power test all leads that are attached to the cd-dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Apr 01, 2011 | Dell (8W007-A01) for Latitude, Inspiron...
Hi , my cd rw crx300e does not respond to discs at all.i may have deleated components, all drivers are up to date,can i check this ?
make sure that the cdrw dvd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cdrw dvd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 27, 2011 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
I have the cd rw HL-DT-ST CD-RW GCE-8483B, for some reason it will view copied discs written by the PC but will not play my PC DVD-ROM. I have uninstalled and reinstalled the device and done a system...
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Jan 07, 2011 | Hitachi GCE8481B CDRW Burner
My disk drive is stuck and will not read the disk. How do I fix this?
make sure that the cdrw/dvd combo is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd combo then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device ?
control panel admistrive tools,computer management,device manager scroll down cdrw/dvd drives?right click you can? you can update driver,roll back driver,or select properties general troubleshoot, select driver? click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 01, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Just looking for a driver fro crwd 2400p cdplayer. The OS the driver is needed for is Windows XP. This peripheral is a PCMCIA cdrw dvd player and was bought from PSISM.com (they keep saying this item is...
Follow the steps given below
Connect the External CDRW to the PC and you should be able to find the green light glowing and CDRW should make some noise like spinning.
Press the Eject button the CDRW and It should open. Put in the Software disk that you have received from your PC manufacturer and it should display the contents on the PC Screen
If not, Click on START button - Click on My Computer - You should find the CDRW displayed in Drives Location.
Double click on it and it should display the CD Contents.
This indicated the CDRW is working.
Nov 09, 2010 | EXP Computer EXP CRWD 2400P (CRWD-2400P)...
I have this lessage on start up: F10= rom based setup
its common.it always come and still if it doesnt allow you to access ur pc then click f10 and then run system in safe mode.
Jun 18, 2009 | HP NC8000: NC8000 Pentium M 1.7GHZ, 512MB...
I am using xp pc,i wish to install nero cd,dvd burner in pc.which can copy,burn,write,play all type of cd,vcd,dvd. help or guide me ti install. i need freeware to download.
Hi pk_mastermin;
There is only trail Software available for download, but HERE is a site that claims it's freeware. I wouldn't be surprised if it was the trail version thou.
Good Luck, and don't forget to leave a rating.
Thanks Mark
Apr 26, 2009 | MSI CDRW 32X12X40 Internal IDE Nero...
Cdrw
In the past it was recommend that the burner be the secondary master. Do to problems like you mentioned. Try making the DVD the slave and the burner the master. Be sure that when you boot up that in the posting that it see the drives right. If the CMOS/ BIOS is set for fast boot you can press the ese or tab to see the post without changing the CMOS/BIOS on most models.
Apr 01, 2008 | Computers & Internet
Televison & Video Logo
22 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
