Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
The Holder Of FINISH Tablets does not open automatically during the cycle and is left entact
  • Indesit Master
  • 12,061 Answers
There is a little motor, or mechanism, that should be activated, this either it has faulted or the drive has faulted or the Microprocessor that "Tells" the driver to drive is faulty, you simply have to test and isolate the exact cause, sometimes also it can get gunked up and requires a clean, Please get your service manual below, have a look at the troubleshooting steps and attempt to locate the cause.
http://appliancejunk.com/forums/index.php?topic=2933.0
Also below, is a DIY link to assist you along with the manual to locate and hopefully repair your unit.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
However as usual if you do not wish to DIY, please call a registered service center and ask them for a "Quote" for the repair when they call.
Posted on Oct 14, 2010
I have a Hormann 5500 series. The door closes but automatically reopens when it touches the ground.
I do not know, but I guess that a "bad" handling of the machine during a move may have maligned parts.
This is only a guess.
Jun 28, 2017 | Washing Machines
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a Dishlex Global 300 and sometimes the detergent was not empying out when i did a wash cycle (seems that the top rack would prevent the door of the detergent holder to open fully) I just purchased...
it could be your water preasure or the water is hard,,,but like with most dish washers the tablets dont desolve all the way,,,you need more of a liquid soap type of a cleaner
Feb 19, 2011 | Dishwashers
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Jan 31, 2008 | GE 24 in. GSD3210Z Built-in Dishwasher
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Powder not dispersing
possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Jun 21, 2007 | Westinghouse 24 in. MDP531 RF...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
54 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Level 1 Expert
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
