Question about Honeywell Programmable Thermostat Heater
Honeywell RTH230B So I bought a new Thermostat and have tried many different wiring configurations to get this thing to work and nothing seems to be right.  The old thermostat has 7 wiring posts.  G - Y - W - RH - RC - RC - B - O There is a short piece of wire that connects the Y to the W. And there is also a short piece of wire connecting the RH to the RC.  There are 4 wires coming out of the wall. Green to the G. White to the W. Red to the RC and Blue to the O.  The back of the thermostat I bought has RH - RC - W - Y - G The manufacturer of the old Thermostat which works sometimes is Alaskan AC and they want to charge me $250 just for a new thermostat. I just bought the house in october and I can't see spending that much on something that should cost 80 bucks or less.  I live in Arizona and it is starting to get hot!!!  Please help me.  SamIam
  • Anonymous Feb 15, 2009
    My old Thermostat burned up last night. While attempting to replace it with a Honeywell RTH2310B I can't get the AC or Heater to come on.
    The old Thermostat had 6 wires/connections: W-O-G-R-C-Y the new one only 5. The instructions for the new one stated not to use the C. I hooked up the wires to the same letter connections and no joy.
  • 97 Answers
Jumper RH to RC and Y to W (Just like the old thermostat) and hook the cable wires as you have indicated with the exception of the blue wire - clip it back - it is not needed. This is a heat pump system so heating and cooling are done by the same unit. RH stands for Red Heat, RC for Red Cool, the W and Y are the neutral sides to the heat and cool control circuit. That should get you going good enough to start learning the intricacies of programming the box.
Posted on Jun 02, 2008
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see . The direct link to the manual in English is .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
The heater runs and doesn't want to shut itsself off
check the wire to the thermometor then if the wire is ok replace the thermostat
Mar 03, 2009 | Honeywell Programmable Thermostat Heater
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
659 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
