Question about Sony MHC-GX450 CD Shelf System
Sony music system MHC GX2000 showing push power protect and denies further operation. please assist me to solve this problem.
    New Friend:
Your sound ic damm new replaced ic and enjoy music
Posted on Oct 19, 2014
5 Suggested Answers
SOURCE: sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Posted on Feb 11, 2009
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Posted on Aug 19, 2009
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
Sonys built-in protection against shorts in the speaker system - of course, like it was by my CMT - CPX1 - there's no problem at the speakers at all - this have to be insured! If everything with the speakers and the speaker cabling is ok it might be the soldering at the S-Master IC's. The S-Master Unit is Sonys Digital Sound System, you'll find inside two identical S-Master IC's srewed togehter on a heat sink.
I recognized that if I opened the system, it was running, touching sometimes the S-Master PCB, it shut down.
Solution: there's a bad / poor soldering at the S-Masters pins (probably because of the heat sinks!). I resoldered all S-Masters IC Pins - that's it - my system is running now.
Posted on Apr 21, 2010
  • 4 Answers
SOURCE: what does it mean when
tursia takava sony rxd9 skupe xakera.1 eli na tel 0890349492
Posted on Jan 07, 2011
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
This is what the manual says:
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
My unit mhc -gx2000 parts has been replaced twice for push power protect same thing again i am seeing. What's the problem would be now?
Is this the picture of the device you have. If yes; this is a very STRANGE ONE.
Never be self promotional. It is not a good practice.
Nov 26, 2015 | Audio Players & Recorders
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
Sir my sony stereo system showing "protect push power" how i troubleshoot the problem please replay fast
Protect Push Power on a Sony is telling you that you have an output short circuit and to turn off the player to prevent further damage.
Check the speaker cables for connection fault. If all is OK it means you have a blown STK Amplifier Chip. Will cost you about 20$ plus labor.
Apr 30, 2011 | Sony MHC-NX3AV Shelf System
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 16, 2011 | Audio Players & Recorders
My sony mhc-rv777d is not working when i on my sony within 4or 5 sec it off automatically so i need a solution
MHC-RV777D shuts off itself because of protection mode that is activated to avoid further damage due to defective amplifier output IC in unit.
You need to check/ replace output amplifier IC to solve this issue, if you are not familiar with electronics stuff repair then local repair shop will do this job for you.
Hope these info will help you.
Let me know if you have additional question.
Nov 03, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Sony MHC-GX450 CD Shelf System Logo
864 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
