Question about Buffalo Technology 1TB DriveStation TurboUSB (2x500) External Hard Drive
I have windows 7. The buffalo hd ce1.0tu2 external hard drive was working, but now, it says it is still there but will not open anything up. When I try to it takes ages to load up then either nothing happens, or it says it needs formatting. Does this mean I should go to a recovery place to try and get my 1500 odd photos off it. I have tried updating the drivers, and that still did nothing. If my computer formats the external hard drive, it will wipe everything, yes?
  • Buffalo Tech... Master
  • 8,071 Answers
Yes it will. Try it on another unit and see if you can get access to your files. If not , then your only recourse is to use file recovery freeware.
Posted on Jun 09, 2017
5 Suggested Answers
  • 130 Answers
SOURCE: my buffalo external hard disk
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Posted on Apr 13, 2011
  • 10406 Answers
SOURCE: WHEN I PLUG MY EXTERNAL
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 10, 2010
ChoiceSmith
  • 30 Answers
SOURCE: I have the Buffalo HD-CX2
If it shows up in 'My Computer' as a drive letter(like E: drive) but you can't access it,I would first try to recover the data on it with a data recovery program to avoid losing them.
I have succeed with Tenorshare Data Recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash.You can get it here: http://www.any-data-recovery.com/index.htm
Next,you can format it to check out whether it can be fixed.
If the hard drive can't be detected,you can try this way.Put the hdd in a zip-lock bag and put it in the freezer overnight. Then while it's still cold plug it into the computer and you may be able to view it in 'my computer'.
If it fails, you will have to go to a recovery office but let's hope not because it will cost you a lot of money and whether they can recover the data or not is not guarantee.
Good Luck!
This article will help.
How To Recover Lost Data From Crashed Hard Drive?
Posted on May 26, 2011
bronk50
  • 27725 Answers
SOURCE: 500gb buffalo external hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Posted on Jun 12, 2011
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
Cannot read or reformat my 500gb buffalo external hard drive
download Acronis Disk Director Suite via torrent. install the program. open the application. locate the drive that is not working. usually its labeled "unallocated". click on the "Acronis Recovery Expert" button. and again select the drive you want to recover/fixed. there are instructions on how you want the program to run its recovery. its pretty simple. bare in mind before running the application. your hard drive should be connected directly to your PCs USB port and not by any hubs. by this. your computer should be able to read your HD again.
Jan 11, 2012 | Buffalo Technology (USA), INC. - 500GB...
My external hard drive (buffalo HD-PE320U2) is not working. when I plug it on the computer it says "windows does not recognize it" or it has malfunction. what will I do with it?please help I...
First uninstall the software,make sure the external hard drive is not connected to the PC and use your install disk to reinstall the software.You might all so try system restore.Thank you for choosing FixYa.com.
May 18, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Will Buffalo Model HD-PE250U2 work with Windows 7 OS? Regards sandra
Yes, it is a "plug-and-play" device, and Windows XP/Vista/7 support "plug-and-play" devices.
Dec 31, 2010 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Buffalo Technology 1TB DriveStation TurboUSB (2x500) External Hard Drive Logo
269 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
