Question about Desa International White Wireless Plug In Door Chime
WDC813 RX. Like Sara Miller my receiver has, in the past, rung of its own accord -- I teach from home and this syndrome can be jolly annoying when I'm in the middle of a lesson. Now, there's an additional problem. The rubber bell push has become very temperamental and I definitely need a new one. Can you please supply one of these without having to buy the receiver too, and is there an alternative to the rubber button? I would much prefer one made in a more solid material. Many thanks, Muriel Daniels. Email:- muriel.daniels@eberlemusic.co.uk
  • 864 Answers
SOURCE: Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Posted on Jul 08, 2009
SOURCE: my bell rings when my neighbor pushes his
Take the back off the 'bell' and you will see two rows of gold colored pins running parallel to each other, eight pairs I think. Three of these pairs of pins will be covered by jumpers. Jumpers connect two pins together.
Pull any one of these jumpers off it's pins and move it to any other pair of pins.
Make note of which jumper (the pins are numbered) you moved and to which pins you moved it.
Now, take the cover off the 'button'. You will see an identical set of jumpers and pins to those in the 'bell'. Duplicate there, the change you made to the 'bells' jumpers.
Ghost rings solved!
Ok, ok, on the wild outside chance that the problem persists, just move another set of pins.
Remember, the jumper configuration in the 'bell' and 'button' ' must be identical.
Posted on Nov 09, 2009
Sec2020
  • 3 Answers
SOURCE: Hello I have now got 2 (two) of these units
This looks like the Heath Zenith SL6162/63
(http://www.1800doorbell.com/db800-wireless-battery-chimes.htm#SL6162)
I have the pdf of install manual if you would like it. This wireless doorbell has over 128 codes that prevent outside interference. Here's part of the manual for changing the code:
Note: Most installations will not require you to change any of the jumpers
on your doorbell.
The doorbell button and chime communicate by using a code that can be
changed by removing and/or adding jumpers on both the doorbell button and
chime. The code is factory set; however, there are 128 selectable codes that
allow you to expand your system and prevent outside interference. Another
wireless doorbell system or other wireless products may cause interference
and the system may not function properly. Follow the instructions below for
setting a new code.
1. Disconnect the power to the doorbell button and chime.
2. Open the cases and locate the jumpers on both the doorbell button and
chime (See illustration).
Attach the back of the
case to the door jamb or
wall. Snap the front of the
button back on.
Holes for
Wall Mounting
595-5611-06 - -
Battery
Battery
Battery
1 2 3 4 5 6 7 8
1 2 3 4 5 6 7 8
Doorbell Button Battery Replacement
Install an alkaline type A23 12 Volt battery. The
positive terminal should be positioned as shown.
* Code Settings 1-7
Must Match Both
Doorbell Button and
Chime
Inside
Doorbell
Button
Inside Chime
3. The doorbell button and chime both have eight different jumper locations.
The jumper positions 1 through 7 are used for setting the code.
4. To change the code, add and/or remove jumpers as needed. There are 128
different combinations. It is recommended to only change one jumper at a
time and then check to see if system is functioning properly. Note: Jumpers
in positions 1 through 7 must be exactly the same for both the doorbell button
and chime for this system to function.
Posted on Jan 13, 2010
  • 4736 Answers
SOURCE: I have a desa
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Posted on Mar 09, 2011
  • 93 Answers
SOURCE: I NEED A PUSH BUTTON
you may wana contact the creator of this object
Posted on May 30, 2011
How can I stop restless;leg sy,[tos
  1. 1 / 16. Sleep Late. Restless legs syndrome, also called RLS, makes it hard to sleep. ...
  2. 1 / 16. Keep a Regular Bedtime. ...
  3. 1 / 16. Stretch Before You Sleep. ...
  4. 1 / 16. Cut the Caffeine. ...
  5. 1 / 16. Soak in a Warm Bath. ...
  6. 1 / 16. Chill or Warm Your Legs. ...
  7. 1 / 16. Make Exercise a Habit. ...
  8. 1 / 16. Exercise Your Brain.
More items...
Slideshow: 16 Remedies for Restless Legs Syndrome - WebMD
www.webmd.com/brain/restless-legs-syndrome/ss/slideshow-rls-remedies Feedback About this result
7 Best Treatments for Restless Leg Syndrome - Healthline
www.healthline.com > Restless Leg Syndrome > Home
  1. Cached
Highlights. Restless leg syndrome (RLS) can be treated with home remedies, lifestyle changes, or specialized medicine. Sleeping on a regular schedule, exercising, stretching, massage, and applying heat or cold to your legs can help ease discomfort.
Home Remedies for Restless Leg Syndrome - Healthline
  1. Cached
  2. Similar
Mar 16, 2015 - With restless leg syndrome, your legs feel like exercising even though ... There are some lifestyle changes that you can make to help ease your ...
Restless Legs Syndrome: Tips for Relief From RLS Symptoms - WebMD
www.webmd.com/sleep-disorders/features/tips-for-restless-legs-syndrome-relief
  1. Cached
  2. Similar
Mar 7, 2007 - 8 Nighttime and Sleep Tips to Ease Restless Legs Syndrome. Regular, moderate exercise may help you sleep better. Warm up to bedtime. Take it easy! Sleep a little better tonight by avoiding nicotine and caffeine close to bedtime. You'll sleep better, and feel better, if you maintain a regular sleep schedule.
www.webmd.com > Brain & Nervous System > Restless Legs Syndrome
  1. Cached
  2. Similar
Restless legs syndrome, also called RLS, makes it hard to sleep. Your legs may ache, burn, tingle, twitch, or jerk. To get the deep sleep you need, try going to ...
Natural home remedies: Restless legs syndrome ' Best Health ...
www.besthealthmag.ca > Best You > Home Remedies
  1. Cached
Since restless legs syndrome (RLS) seems to be related to mineral imbalances ... But if they don't stop your in-place pacing, you'll want to develop some pre-bed ...
Restless Legs Syndrome (RLS) Treatment - National Sleep Foundation
https://sleepfoundation.org/content/restless-legs-syndrome-rls-treatment
  1. Cached
Restless legs syndrome (RLS) is a serious, but treatable condition. ... These may include drugs used to treat high blood pressure, heart conditions, nausea, ...
Restless Legs Syndrome Treatment - Lifestyle Changes & Home ...
www.everydayhealth.com > Restless Legs Syndrome
  1. Cached
Jun 29, 2016 - Restless Legs Syndrome (RLS) typically treated with lifestyle changes and ... The goals of RLS treatment are to prevent or relieve symptoms, ...
Restless legs syndrome - Treatment - NHS Choices
www.nhs.uk/Conditions/Restless-leg-syndrome/Pages/Treatment.aspx
  1. Cached
  2. Similar
Sep 2, 2015 - Find out more about the treatments for restless legs syndrome (RLS), ... may be enough to ease the symptoms of restless legs syndrome.
Restless legs syndrome Treatments and drugs - Mayo Clinic
www.mayoclinic.org/diseases.../restless-legs-syndrome/basics/treatment/con-2003110...
  1. Cached
  2. Similar
Nov 1, 2003 - Restless legs syndrome - Comprehensive overview covers symptoms, ... Most drugs prescribed to treat RLS/WED aren't recommended during ...
Restless Legs Syndrome: How to Stop Twitching Legs ' Wellness ' US ...
health.usnews.com/health-news/.../restless-legs-syndrome-how-to-stop-twitching-legs
  1. Cached
  2. Similar
May 11, 2013 - Do you have sudden urges to move your legs? Here's how to stop the uncomfortable sensations.
How can stop restless leg Google Search
Nov 07, 2016 | Computers & Internet
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
Jan 12, 2016 | Yamaha RX-V540 Receiver
What Years was the JVC Rx-208bk Made?
This link suggests year 2000 (twice):
RC: JVC RX-208BK Receiver (RTI Family)
http://files.remotecentral.com/view/6345-16801-1/jvc_rx-208bk_receiver.html
Jul 16, 2014 | JVC Rx-208 Rx-208bk Am/fm Digital...
I cant auto tune my yamaha rx v 365 reciver because i get an error saying that i dont have my speakers connected even though i know they are and working just fine.
1.Check you select the good set of speakers according to the connections you made at speakers output.
2.Have the soldering of your power output IC module remaked (by a technician only).
Spider Guy
Mar 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Desa International White Wireless Plug In Door Chime Logo
106 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
