Question about Maytag Neptune MDE5500AY Electric Dryer
Bake Element How would bake element (AP374912) for 30" oven be installed?
Not that easy... we did that and did not realize there were wires attached. It sparked and shut the oven off. How can I install it safely? Do I need to hire an expert... not that simple
Posted on Oct 26, 2008
  • 868 Answers
Un screw it and put the new one in.
Posted on Jun 02, 2008
How do I access the top/front screw on the right side while standing in front so I can remove the side panel to access the bake element.
I didn't look up your problem, but it reads like you'll need an offset screwdriver to fit between a wall and the right side of the dryer/oven/whatever. There are also ratchet-type offset tools that might help expedite the removal.
Jun 02, 2015 | Dryers
Ge installation manuals
This is a very easy one to fix!. Follow these tips, carefully:
1. Turn off the oven with all knobs to lowest temperature, oven off etc. (obviously!)
2. Turn off ALLl electricity to the oven using the electrical breaker box. It should be a double wide switch since it is a 240 volt oven. If you are not sure, turn oven on, and then flip the wide breakers (and turn off oven when you find it!!) .
OTHERWISE, turn off ALL electricity to the house. That is the master breaker at the top of the breaker box. Make sure the electricity is OFF. You can work safely now. Use a flashlight in oven if needed since the inside light will be off too..
3. Take out all racks and items out of the oven so there are no obstructions.
4. Take out the old element by first unscrewing the screws on the sides of the face plate, using a phillips (cross) screw driver. Keep screws handy. Don't toss them or loose them.
5. Wiggle the element side-to-side holding it in the BACK of the element with two hands. It should come out easily if you gently wiggle it, and then pull. Do not just pull it at the end of the loops or sides of the loops. Use the back v shape part closest to the stem.
6. INSPECT THE ELEMENT. Do you see any black steaks or burn marks beyond the face plate that indicate arcing of the electricity? If so you may have a short inside the element holder. Then you need to call a repair person.....
7. If there are any spacers or L shaped attachments on the old element, take them off to use on the new element. you can clean them with vinegar and soup and water.
8.. Take time to CLEAN the oven floor and hard to reach areas in the back of the oven, since everything has been removed. You can use Easy-Off, or spray stuff, but please remember to wipe it out. Use a spray that can be used in a COLD oven. Use VINEGAR and then a solution of baking soda to fully clean out the lye-based cleaner. Don't spray stuff into the holes for the element!!! Just wipe that with vinegar only. Let it dry thoroughly. Isn't nice to have it so clean?!
9. Take the NEW element out, and use a CLEAN paper towel/cloth towel to hold it at the V section. Inspect it and the prongs. Using the towel will prevent getting hand oils/sweat on the element that may cause corrosion later.
10. If the new element does not have spacers or L feet on it to keep it off the floor of the oven, use the old element's feet, after they have been cleaned and dried. Gently pop them on in the same locations.
11. Hold the element with the towel in both hands in the V shaped area in the back of the element. and set the prongs into the hole/outlet, and push GENTLY, wiggle it back and forth as far as it can go, and push it in straight. The face plate should be snug against the back wall and aligned with the screw holes.
12. Screw in the screws, but not all the way, either with the new ones that came in the kit, or the old element's screws. Tighten them in slowly, and do it for the left one a little, then right one, By alternating the tightening of the screws, you can keep the element aligned, and prevent bending of the face plate. Tighten them so the element will not wiggle or move, but NOT too tight, forcing it. since you may need to replace this element someday, and the oven heatup/cooldown cycling may make it impossible to unscrew it later.
Now, turn on the electricity at the breaker first. Turn on the oven SLOWLY to about 200 F, to see if the element heats up uniformly. You can use your hand about 6 inches above to check the entire coil, but don't touch it!!!! If there are cold spots, or it is not heating up, check your work above and repeat carefully.
If it heats up uniformly to 200 F, then step it up to about 300 F, and see if the red glow is UNIFORM on the entire coil. You can go up to 350 F and let it "bake in" for at least 15 minutes to when the oven reaches the set temperature. Watch to see how the red glow dies out too. It should be uniform.
If the element does not heat uniformly or you see any very bright regions with dark areas near it on it or sparking, REMOVE it and get a replacement. Sometimes the new element has been "cleaned" with chemicals or handled poorly at the plant that cause problems.
After it " bakes in" for at least 15 minutes, any residues will be burnt off, and if glowing uniformly, it is good-to-go. Put back the racks, and enjoy.
Oct 24, 2013 | GE WB44K10002 Broil Element
Roper range oven
follow this steps and fix it. God bless you
.Bake element
Replace if found defective
1.Broil element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangeoven-repair-help.html#electric#ixzz2ab45pXtc
Jul 30, 2013 | Dryers
Bake Element and Broil Element are not working
if both are dead then its most likely the control board id defective or you are missing one phase of the 240 volts needed to heat the elements
Jan 06, 2013 | Dryers
Why doesn't my oven heat
If neither your bake or broil is not working. The first thing taht you should check is your safety Hi Limit. Part# 318003614. You will have to remove your oven to gain access to this. it is located behind the oven cavity. Typically blows after a self clean. Careful to switch off your circuit breaker.
http://www.on-timeapplianceplano.com/ovenrepair.html
Jul 23, 2012 | Dryers
Wall oven bake element split
Was there a burning smell before at the time when it heated up slowly?A burning smell suggests there was a (possibly continuous) spark at the splitted place.If it was split earlier then the slower warming up was possibly due to a continuous spark, because then there won't be much energy left for heating.It's like an added resistance.So it could've been there for a while already.
The element just needs to connect again where it splitted and should stay there, then it should work again.
Jan 22, 2012 | Dryers
The burners work but the oven does not.
you need a new bake ignitor (if you have a bgas oven) if you have electric check for cracks or anything on the heater element, if no evident obvoious cracks in the heater take it off (two screws usually and slowly pull it out it has two wires on it) take of the wires and check for ressistance if your meter reads a number other than one than your heater is good and you might have a bad thermostat and that you would have to chec k the wiring
if you read infinity( usualy it would just show the number 1, set the meter to the highest scale on the resisstance scale) you have a bad heater
good luck
Jun 09, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
