Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
6800 john deere hitch won't go down - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
  • 143 Answers
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
IF the rest of the hydraulic system has normal pressure, then the control valve for the 3 point may be faulty, or ; the hydraulic cylinder that raises/lowers the 3 point arms has failed (the sealing ring on the internal ring has torn)
Posted on Jun 20, 2009
RonPark
  • 855 Answers
SOURCE: Manual needed for JD 3 bottom plow w 3 point hitch
The first thing to do is get all the information you can off your plow. Like: serial number, model number and any info on any tags you find then go to the John Deere web site. Go to the plows section and you should find everything you need. They do have parts lists and manuals on the site. But it may be harder to find parts without at least a model. But they do have help areas you can try. Try there and if no luck try to give me all the info you can about what you are looking for and I'll do some research for you.
Posted on Sep 13, 2009
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
  • 66 Answers
SOURCE: My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
Posted on May 30, 2010
  • 146 Answers
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Posted on Jul 04, 2010
Will a john deere snowblowerfrom a 445 fit on a 485 john deere?
You will need longer hydraulic hoses because the ports are on the opposite side of the 485 but will work. If the 485 has mower deck it will have to be removed or buy a quick hitch to set the blower back a little further. Go for it....
May 29, 2017 | John Deere Garden
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
I just got 7210 john deere tractor i cannot get the three point hitch to go down what can i do?
We have had problems with light rust on the cylinder walls. Honed the rust out and lift worked great
Feb 05, 2012 | John Deere 7200,7210 All W/o Cab Tractor...
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
99 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
