Question about Philips GoGear HDD6330 MP3 Player
Please help philips mp3 gogear SA 3125/37, When i turn on the player say please connect the pc and use device manager to repair
  • 1 more comment
  • brwnsuga24 Jun 05, 2008
    my mp3 player cuts on but after it passes the gogear screen it goes straight 2 please connect player to pc what can i do to fix this
  • Anonymous Aug 21, 2008
    yes I was coping a pic to my phillips player and it stopped and said connect player to pc It will not work anymore. I guess i must be junk thats my luck why I buy stuff
  • Nakuru Sep 13, 2008
    When i urn on the MP3 player it says please connect player to pc. have tried pushing the off button plus increase volume but it doesnt work. the devise is not recognised by the computer.
Try to hold down the power button while pushing the volume button up at the same time. This resets the device. It should help
Posted on Jun 08, 2008
Hi team,i am facing problem with philips go gear 2GB player, Problem is :when ever i switch it on,"please connect to Pc and use device manager to repair" please help me in this scenario,explain...
I'm not a team member, but
1. Select your GoGear 2GB player from this list:
http://www.search.philips.com/search/search?q=GoGear+2GB&s=all&l=global&h=all&o=
2. When not having the program Philips Device Manager installed on your computer yet: Look under Software and Drivers, select the Device/Firmware Manager for your player.
2.1 Run the execute file Device Manager for installing the Device Manager toolbox.
3. Run Philips Device Manager:
  1. Having launched Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA2XXX -> Philips SA2XXX Device Manager on your PC
  2. Connect your player to the PC
  3. Device Manager should acknowledges your player and automatically goes into recovery mode.
  4. Follow the instruction of the Device Manager.
  5. After the player has been repaired, remove it from your PC and re-start.
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Philips Audio Players & Recorders
When i turn on mp3 player it says phillips for a minute then says file system error then shuts off then i hook it up to the computer and the phillips thing dosent come on its like its not hooked up but...
Hello.
Welcome To Fixya Community.
Glad to Help You Sir ^^
Most likely this kind of problems occurs when the Mp3 Player's Firmware Corrupted, In Order to Fix that you shud upgrade/install the Firmware to your Mp3 Player.Please Follow these Steps to Fix Your Problem:
  1. Download the attached zip file into a temp folder of your PC
  2. Unzip the file into the temp folder and then double click theDM_WEB_ENG.exe file to install the latest version of the Device Manageron your PC
  3. Follow screen instructions to complete the installation of the latest version of the Device Manager application on your PC..
  4. Connect the GoGear to the power supply with the AC/DC adapter.
  5. Make sure all other applications such as Philips Device Plug-in,Windows Media Player or Windows Explorer that accessing the device areclosed or else Device Manager will not recognize the device. Launch theDevice Manager at Start->Programs->Philips DeviceManager->Philips Device Manager on your PC.
  6. Select the REPAIR tab on the dialogue box and then click Repair to start repairing.
    IMPORTANT: All music & content of the device will be erased once the GoGear is repaired.
  7. Once the repair is complete a dialogue box will pop up; click OK andunplug the GoGear from the computer. Follow all screen instructions tocomplete the repair.
  8. The Device Manager will close automatically once the success message isdisplayed. Close all opened application and then unplug your device.
Once the GoGear is disconnected from the computer, the display willshow “Firmware Upgrading” for a couple of seconds and then start up asusual. You will then need to re-sync the GoGear using Windows MediaPlayer to place your files back on the GoGear.
Downloads:
HDD6320_6330_DM_WEB_EN​G_5_2.zip
Additional Help:
Philips GoGear Jukebox HDD6330 Manual Guide
Thank You for Using Fixya
Please Don't Hesitate asking me If you need any Further Info.
Good Luck
Nov 05, 2009 | Philips GoGear HDD6330 MP3 Player
NOT'''' RESPONDING
Connect your mp3 player to the computer.
Open the Philips Device Manager
Run the Repair function.
If the Device Manager does not recognize the player, connect the player to the computer (while the player is in the OFF position) while holding in the volume + button. Continue holding the vol + button for 5-15 seconds until a window pops up on the computer screen that says Found New Hardware Wizard. Follow the directions and it will lead you to do a Repair in the Philips Device Manager.
If this strategy doesn't work, your player is screwed. Call Philips and find out how to get an in-warranty replacement (or take it back to the store).
-Tha Mp3 Doctor
Nov 16, 2008 | Philips GoGear SA178 MP3 Player
Can't turn off
You have to hold the button in for about 5-7 seconds, and then it will say "Bye" and shut off normally.  If it won't shut off because it has frozem, then reset the device. If it continues to freeze, run a "Repair" in the Philips Device Manager: Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Sep 13, 2008 | Philips GoGear SA3125/37 MP3 Player
Philips GoGear 2GB memory corruption
You have to do the "update" in the Philips Device Manager (make sure you are connected to the internet when you do) to repair the corruption: Recovery Mode for Philips' GoGear
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 10, 2008 | Philips GoGear HDD6330 MP3 Player
I pod
-Tha Mp3 Doctor
Aug 28, 2008 | Philips GoGear HDD6330 MP3 Player
A problem with my philips gogear...
The Device Manager came with the installation CD. If you lost the installation CD, you can get the Device Manager by going to www.usasupport.philips.com and entering in your model #, and going to "software & drivers"
If Device Manager is already installed, you can find it by going to Start --> All programs --> Philips Digital Audio Player --> Philips Device Manager
Jun 22, 2008 | Philips GoGear HDD6330 MP3 Player
Philip's Go Gear 30 GB
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
You must do a firmware upgrade to resolve this issue.
Open Philips Device Manager (Go to Start--> all Programs--> Philips...), and click on Update tab
OR
You can get it from www.usasupport.philips.com
It will delete all songs off your player, so be forewarned
Enter your model number on the website, click the link on next page that says SA 5125/37 w/o a "b" on the end
Click on Software and drivers tab
Click on firmware upgrade software - instructions enclosed
-Tha Mp3 Doctor
Feb 08, 2008 | Philips GoGear HDD6330 MP3 Player
PLEASE CONNECT PLAYER TO PC
-Tha Mp3 Doctor
Sep 22, 2006 | Philips GoGear HDD6330 MP3 Player
My mp3 player wont turn on and my songs are gone
First, try uninstalling and reinstalling the software.
If that fails:
-Tha Mp3 Doctor
Sep 04, 2006 | Philips SA-177 (512 MB) MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
166 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
