Question about Dell OptiPlex 360 Desktop Computer
Another cd-rom icon appeared on my computer & don't know how to remove it
  • sama7 Oct 14, 2010
    tried the solution but didn't work because the extra icon didnt show in the computer managment tool
  • Dell Master
  • 1,183 Answers
You can check the following link to follow step by step instructions on how to remove the drive letter.
Click to Change,Add,Remove a drive letter
Thanks for using Fixya
Proton
Posted on Oct 14, 2010
I have a cd I put in, but do not know how to remove it from my computer need help
1. Open the Computer window on your PC: Either double-click the Computer icon on the desktop, or open the Start menu and choose Computer.
2. Click the DVD drive icon: Clicking the icon selects that drive.
3. Right click on it and choose 'Eject' from the drop-down list.
OR
Try the following only if the above steps didn't work or in times of urgency, such as when the computer is locked up (or turned off), you can manually eject a disc/cd by pushing a straightened paper clip into the tiny hole (the "beauty mark") on the front of the DVD drive.
f90a6593-7fec-4205-a633-379cc4b71e53.jpg8572a8b8-67cd-4c33-bbf8-d5d51bfdd48d.jpg8681c4da-0608-43dc-b4b8-cee760b38e11.jpg
Nov 28, 2013 | Computers & Internet
My printer does not appear in my computer
Hi
May you remove or uninstall by mistake that's way is not showing now don't install again to follow the mention below instruction.
1) Plug on you USB cable to PC and power on the printer.
2) Put the Lexmark printer software installation CD in you computer CD-Rom.
3) Open the CD-Rom, and duble click the setup exe.
4) The setup will take few minute to install the driver.
5) After installing the driver reboot your computer. and start to printing
Cheer
Aug 03, 2011 | Lexmark X4650 InkJet Printer
I don"t have a cd - rom
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 27, 2010 | Canon PowerShot A460 Digital Camera
I inadvertantly removed the functional software installed for this device. The icon is no longer displayed when I open "My Computer". Since I do not have a functional CD DVD Rom device am unable to...
try taking out the cd-rom out of the system and then hook it back up. Go into your BIOS and see if its being recognized in there, if it is then let it boot back up into windows and see if the device is okay. If its sitll not then try another known working device in there and see if the cd-rom works now. If it does then you know the original cd-rom was bad. If it still doesn't then it could be the motherboard controller that the cd-rom hooks up to is bad.
in the BIOS, If the cd-rom doesn't show up or if it shows weird symbols then try another cd-rom and if you get the same symptoms then the motherbard is bad.
Jul 16, 2009 | Computers & Internet
CD ROM DOES NOT APPEARS ON MY DESKTOP. WHEN I OPENS MY COMPUTER THERE`S DOES NOT APPEARS THE CD-ROM`S ICON.
1.check your connections of CD Rom inside the Cpu box, if any loose contacts there, then your cd rom wont appears on the computer,
2. change the data cable
3. connect different power socket to the cd rom
4. goto Bios setup, press Del key or F2 key to enter the Bios setup
5. check your cd to detect
6. save it and restart your computer
Jun 22, 2009 | Intel D101GGC Motherboard
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Dvd/cd rom drivers
try dell.com for driver downloads for your drive.
or uninstall it from your device manager and reboot and it might fix itself
Apr 04, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
Trying to install new hp photosmart printer c4280. the startup disk does not appear on the screen. i tried the my computer icon but it does not show the cd-rom icon. my computer is a hp pavilion xe783 and...
check the cd in another rom,if it is working fine than clean your cd rom with lens cleaner if the problem persits than try with another data cable, if not solved then try with another cd rom
May 30, 2008 | HP Office Equipment & Supplies
No cd-rom icon appears
install a mp3 player /take i tt o
Feb 09, 2008 | Computers & Internet
Dell OptiPlex 360 Desktop Computer   Logo
32 people viewed this question
Alun Cox
