Question about Garden
How do i pull apart talon eagle trimmer to replace pull cord?
    President:
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers.
Posted on Oct 14, 2010
Does the american eagle pull out its feathers?
No this is a complete myth. This has been researched and found to be untrue. If eagles were to pull out their feathers and talons, they would starve to ***** as they could not hunt. They would also have no protection against the cold as feathers are their insulation.
Mar 26, 2016 | Miscellaneous
How to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Mar 18, 2015 | Garden
1995 eagle talon manual transmission i'm able to put my clutch down and shift gears, but car wont accelerate
Something is broken, that is for sure, pull the transmission out and first look at the clutch plate.
Jul 08, 2012 | 1995 Eagle Talon
Charging system
Well, if the link is burning, something major is wrong, replace the link alone and it would certainly fail again. I suggest that you pull the alternator and get it bench tested. I suspect diode problems...
May 30, 2010 | 1995 Eagle Talon
I have a Talon electric line trimmer AT2309A and cant even seem to move the starting button to get it to work. Please help.
You need to move back the safety button on top of handle first. The safety button can be a bit stiff to move.
Nov 07, 2009 | 2006 Eagle Talon
Line trimmer not starting
The primer button may have a hole in it due to drying out. The little plastic bubble may not be priming the carburator prior to start. Leave on full choke and pull several times if still no start check for fresh and correct fuel/oil mixture if required. I am assuming this trimmer is not electric. If trimmer still fails to start or starts and runs for a moment and shuts off replace the primer button, the carb. is sucking too much air.
Sep 21, 2009 | 2006 Eagle Talon
Replaced head gasket on 91 eagle talon turbo
clean out the plug ins with electrical cleaner...sounds like something isnt plugged in or got cut or grounded out when u took all that stuff apart
Jul 25, 2009 | 1991 Eagle Talon
1991 eagle talon
simple!!!!!! pull the old one out and install the new one reverse of the disasembly. if that is to hard take it to a mechanic. besides that the water pump is on the opposite side of the timeing belt. the timeing belt doesnt cover any of the bolts for the water pump.
Aug 14, 2008 | 1995 Eagle Talon
1995 Eagle Talon Will not start
check the mass air flow sensor, if this is bad then the ecu wont get a signal and it wont send the right amount of fuel to the cylinders causing a no start condition
Jun 25, 2008 | 1995 Eagle Talon
Garden Logo
184 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
