Question about Acer TravelMate 345T Notebook
How to replace CMOS battery, how disassemble laptop? I opened 13 shrews underside
    Genius:
  • 1,035 Answers
Hi. I have an instructional video on how to replace the battery of a travelmate laptop. Please click here.
Posted on Oct 14, 2010
Ibm think pad 2611 1452 cmos battery how to replace
There are multiple panels on the underside of your laptop. You can start by removing those and seeing if you can locate the battery there. If it is not under those panels than try removing the keyboard. If you still can not locate the battery from these then you will need to completely disassemble you laptop chassis to locate the battery.
I wouldn't suggest disassembling the entire chassis as reassembly can be difficult.
Nov 21, 2011 | IBM ThinkPad Computers & Internet
Can you remove cmos Battery from acer aspire 7520
See http://www.acer.co.uk/ac/en/GB/content/drivers then select your Acer Aspire 7520 which will then give you access to the User Guide for this laptop.
In the User Guide - under Troubleshooting Tips and Error Messages it says:Error messages Corrective actionCMOS battery bad Contact your dealer or an authorized service center.CMOS checksum error Contact your dealer or an authorized service center.
This suggests that you would need to take your laptop to a dealer or service centre to get the CMOS battery replaced which would be advised if the laptop is still under warranty.
The alternative would be to open any covers on the underside of the case and see if your can see a small button cell type battery that you may be able to get a replacement for. Please note that you should remove the main battery before opening the laptop case and ensure that you ground yourself to avoid damaging any components with static electricity from your clothing etc.
Oct 30, 2011 | Acer (ACERMOTHERBOARD)
How do you replace the cmos battery on acer aspire 7520
Need Bios password for Aspire One D255E Forgot my password need to reset to factory default
Check my hint at: http://www1.fixya.com/support/r5953318-reset_bios_password
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Oct 01, 2011 | Computers & Internet
Need to disable cmos password protection (ex-girlfriend issue!). Does it need to have a jumper disabled or is there another way? Thanks
After a quick read-through of the user manual for the P505-S8950, the only way to discharge the CMOS memory seems to be removal of main battery and power cord for and extended period of time in order to cause the CMOS battery to discharge.
There may be a way to open the laptop and remove the CMOS battery to speed-up this process; however, my previous experience with taking apart a Toshiba laptop led me to the realization that they are not designed to be easily disassembled -- I had a heck of a time reconnecting the display data cable (I had to use a chopstick and have a lot of luck to get it back together).
I would suggest opening each of the access doors on the bottom of the computer in order to determine whether or not you can get at the CMOS battery that way; otherwise, I think your stuck with waiting a LONG time for the CMOS battery to discharge or VERY carefully disassembling the laptop.
Dec 29, 2010 | Toshiba Satellite P505-S8950 Notebook
I need instructions on replacing cmos battery? Where is it located on the hp compaq nc 6220 laptop
Please click here to open the service manual
1.Prepare the computer for disassembly (refer to Section 6.3, “Preparing the Computer for Disassembly,” for more information).
2.Remove the cmos battery (refer to
Section 6.24, “System Board,” for more information on removing and replacing the RTC battery).
CompQ
May 12, 2010 | HP Compaq nc6220 Notebook
Urgent help needed to locate cmos battery laptopasus x51r series
The cmos battery is on the motherboard and unless you are competent at disassembling laptops then I suggest you take it to a repair shop for battery replacement.
Jun 09, 2009 | Acer Aspire 3690-2196 Notebook
Disassembling ASUS Degatto Laptop
The cmos battery is held beneath the plastic shelf directly below the hard-drive. You will either need to force the shell apart enough to get to it; or, do like I did and remove the HD and carefully use an exacto knife to cut a small square out of the HD shelf. Just remember to cit slowly and let the knife do the work, not forcing it through the plastic! Patience grasshopper will bring great rewards! Hope this helps! J
Nov 11, 2006 | ASUS Degatto Notebook
CMOS replacement for ASUS d1
It's difficult to say but you will need to remove the underside screws and also maybe even the keyboard as it's often attached to the base. The cmos battery could also be behind the screen. Comment by sandrew, posted on Nov 12, 2006 I'm sorry but I dont have any personal experiences with your particular laptop, but the lcd's are generally held in with 1 screw in each corner normally covered by a rubber bung hiding the screws, I would be very carefull not to disconnect any wires behind the screen, if yor not sure take it to a qualified repairer. You will probably have to remove the top panel just below the hinges as they may be held in underneath
Acer TravelMate 345T Notebook Logo
187 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
